Page 85 of 177 FirstFirst ... 3575808182838485868788899095135 ... LastLast
Results 1,261 to 1,275 of 2641
Thread: VVDI KEY TOOL
  1. #1261
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by labusas View Post
    Can anyone tell me if id48 VOLVO cloning works with VVDI key tool? I tried with VVDI2 and can not get past first step of 8 to sniff out
    perhaps data was not read via Data Colector
    keytool give Biiip when you place them close to ignition, so you can hear signal is detecing.
    Combinate keytool with VVDI2 and use
  2. The Following User Says Thank You to Maartinj For This Useful Post:
    labusas (14th April, 2018)
  3. #1262
    I'm trying to copy old a3 8p0. I'm 16 in queue and need wait 80 min's. Does it always take so long?
  4. #1263
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by EMCE159 View Post
    every calc need 5 min, if many user waiting .. ...you next
    soon they will fix this
  5. #1264
    rob h's Avatar
    May 2011
    Keytool failed on this car.
    Nissan Note 2007 ( same as Micra)
    Regular remote key.
    Pcf7946 vdo siemens 5WK4
    433 mhz ask 2 button
    I tried to create a spare key. Using a xhorse remote key.
    Programmed succesful, car starts, but the remote did not work!!!!
    I checked the org key, 433,2mhz ask
    the new xhorse key, 433,9 mhz ask.
    It is not listed in the vvd2 keytool.
    So i created it using the handheld key tool.
    Wil this be fixed, and then also added in the vvdi2?
  6. #1265
    keyprogramming's Avatar
    Volvo is very problematic, even with Silca T48 cloning
  7. The Following User Says Thank You to keyprogramming For This Useful Post:
    labusas (15th April, 2018)
  8. #1266
    castin's Avatar
    Oct 2015
    MIcra 2006 - Key Tool snif org key (PCF7946), but not show remote page (user page show ok, but only "00 00 00 00"). OTP area is FE in this key, so i think not possible to read remote info page. Car start OK, remote not work.
  9. #1267
    DK Veteran labusas's Avatar
    Nov 2010
    wrong post
    Quote Originally Posted by rob h View Post
    Regular remote key.
  10. #1268
    Nov 2010
    I was not able to clone VOLVO yet. The collector works OK with VW.
    Some other tool in the video tells you to wait 5 min after first step with the key out. Then it collects ok.
    Could this work with VVDI?
    Quote Originally Posted by keyprogramming View Post
  11. #1269
    rob h's Avatar
    May 2011
    Quote Originally Posted by castin View Post
    I wrote, program a remote key. This means creating a virgin key suited for this type.
    So, i created a xhorse key, with transponder and remote on a single pcb.
    With the pin code, i then programmed it by obd, using avdi.
    Car started, and the remote should have worked!
    I did not try the sniffing, i wanted a fully working remote key.
    And i did not try to clone the transponder, and remote seperate.
    Dont know if that could work in this case.
  12. #1270
    Greece
    This function is for precoding original key not xhorse key. For example precoding a used key ufter replace the 7946
    Στάλθηκε από το F3311 μου χρησιμοποιώντας Tapatalk
  13. #1271
    rob h's Avatar
    May 2011
    Hello Kleidaras,
    A Micra or Note original key does not need precoding.
    It is always ready to be programmed by obd.
    With this keytool function, i made pcf7946 keys, for Psa models. Using xhorse keys!
    They always started, and the remotes worked.
    In this menu, there are also lots of keys that require to be connected with cable suplied with the vvdi key tool.
  14. #1272
    Greece
    Sorry i think you try genatate transponder selection on vvdi. I mean with generate transponder you can write precoding on micra key if replace the pcf 7946 on used key
  15. #1273
    Mar 2017
    Did anyone else pay $250 for ID48 activation and did not get the 1500 tokens??
  16. #1274
    ghostrider72's Avatar
    Jul 2012
    UK
    Did someone tried clone Honda Civic 2008 immo and remote with VVDI Tool?
  17. #1275
    I think I'm not gonna invest in the future on this tool. Its developed to slow, no support, and many things failed in comapration with keydiy KD X2.
