Page 88 of 177 FirstFirst ... 3878838485868788899091929398138 ... LastLast
Results 1,306 to 1,320 of 2641
Thread: VVDI KEY TOOL
  1. #1306
    Oct 2016
    Scotland
    Quote Originally Posted by fahmidhassan View Post
    Can I use TPX3 instead of special ID46 cloning key? Because that special chip is not available in my area.
    Sent from my HUAWEI RIO-L01 using Tapatalk
    Yes, i've used TPX3 with the VVDI Key tool.
  2. The Following 2 Users Say Thank You to WRX 14 For This Useful Post:
    fahmidhassan (29th April, 2018), nagib (29th April, 2018)
  3. #1307
    Feb 2014
    Wonder why it refused to write on the TPX4 which I have. It is the latest FW version...
  4. #1308
    Sep 2013
    Friends Volvo xc 90 can't copy id 48 aqustition data 8 times ok but write retry again retry and 5 times nothing.How its works do somebody done it?
  5. #1309
    dyzio's Avatar
    Jan 2014
    Racek
    Quote Originally Posted by holbi1 View Post
    what transponder u use?
    Be yourself; everyone else is already taken.
  6. #1310
    Sep 2013
    It colect data from ignition coil and when later you put orginal key in key tool cant read so I try retry 5 times and nothing.It wont put me to copy transpoder friend
  7. #1311
    Jul 2016
    What chip were you trying to copy ? I did id46 this way....first read the chip then press clone and sniff data from ignition coil then you will be asked to put the original key inside the induction coil for calculating key data. *be careful when calculating because the tool can't calculate key data if the key is not placed in proper position* I had difficulties placing the key and failed several times.
    Here is what I did: read original key » sniff ignition coil data » calculate original key data( first put the key into the induction coil and notice the progress bar should show increase in percentage if not then slightly move the position of the key until the machine read percentage) » calculate successful » remove the original key and place recommend cloning transponder into the coil » press copy( if it's Hyundai ID46 key then you should see READ MORE!! And Here you can get the pin code) »Successful (Done!!!)
    I'm sorry if it's too much to read....Thanks
  8. #1312
    Sep 2013
    Friend I did plenty of id 46 vvdi key tool volvo got id 48 and after aqustition data cant read when you put in vvdi key tool antena but some peole says that volvo is not easy with key tool
  9. #1313
    Sep 2013
    Or mabe difrent question have you done any volvo on Id 48?
  10. #1314
    DK Veteran labusas's Avatar
    Nov 2010
    I tried on XC90 and it failed past step one of sniffing.
  11. The Following User Says Thank You to labusas For This Useful Post:
    holbi1 (4th May, 2018)
  12. #1315
    Sep 2013
    So in my case the same friend
  13. #1316
    Same problem here with Fiat Bravo 2007my, ID48 96bit copy...
  14. #1317
    Apr 2015
    friend, Volvo model is special for collect data from switch, usually the ignition signal for acquisition every 15mins will change one time.
    such as:if you use VVDI KEY TOOL to collect data within 5mins several times, you will get stuck at 1/8 collect data.
    have to wait around 15mins later then do next time collect data, then will get 2/8 collect data.
  15. The Following User Says Thank You to Samic For This Useful Post:
    fahmidhassan (5th May, 2018)
  16. #1318
    Apr 2015
    Quote Originally Posted by darkoman View Post
    mate, please post the problem in detail, will check and help.
    also ensure device and APP is latest version.
  17. The Following User Says Thank You to Samic For This Useful Post:
  18. #1319
    Sep 2013
    Samic good you are here so first step of 8 times sniff data from ignition went ok propally 8 times aqustition data second step you have to put orginal key id 48 and read it and in this moment cant do nothing .Thats the point
  19. #1320
    Apr 2015
    friend, you use APP online 96bit copy48 or directly use device offine copy48?
    by the way, the new 48 transponder should be support change ID.
