You can try use your phone hotpot. I just test with mine. Seems failed to connect with server. And can you tell me which country you in?
Not possible with vvdi key tool max when i plug usb I show android directory but not files of data of immo tool I can add files but not in good directory.
Envoyé de mon iPhone en utilisant Tapatalk
Hello problem fixed with update 1.4.3. Today. 1.4.2 was the problem.
u.s (30th September, 2021)
I have Problem with VVDI key Tool. First i can‘t Rewe any KEY in Adapter. I Buy key Tool Max now and it works Fine with the same keys
so i Update the old Key Tool
After Update i Start the device but Show only DEF . I do this with new Update Kit Soft
i do ist after use the Button repair but again Same
any Solution for it
JFR-Tuning (1st October, 2021)
Hi thnx it work
for all i explane it
please select lanquage in XHORSE Update To eng. Also update is startet it ask witch language you need. Also you must select eng
all work fine
autoTkey (1st October, 2021)
Hi to all,
anyone know how to unlink my vvdi key tool from old account?
My device is linked to an account with an old phone number that I haven't had for a long time.
I log in on the app with this old number and I see the "unbind" option but it is sending a code on this old number and I can not get it.
Thank you all for your help.
The thanks button does not burn, you can press it without any risk !
Only Xhorse can help you with this.
KADE007 (20th October, 2021)
Ok but how to contact them ?
I tried with the app but it doesn't work ...
Ask them what are the options to convince them you are the owner. Use the chat option in the app but be careful to contact them within their worktime or they will not reply.
Maybe it will help if you can show them a document from the telephone company that proves you are the same person who owns your old and your new number. Just talk with them, only they can help on this.
You can try finding them on Skype too. Just type Xhorse in the search bar. You can also contact with the shop who sold you the tool. Or just sell the old equipment as used and buy a new model - VVDI key tool is outdated anyway.
KADE007 (21st October, 2021)
Thank you all for your help. I managed to chat with them and they say there is nothing they can do. I told them that it is not normal that we cannot access our account with email to modify our data. a phone number can change many times in a lifetime, an email address is always available.
