Friends strange things with mini key toll I got new one and try to generate citroen 0523 ask and before generating shows info on app that after generate remote generate transponder is strange its generate 7936 when i checked schold be 7941
Are you guys able to generate a Civic 06-2013 NF5-AO5TAA remote on a super remote? My original keytool says 'please use wireless remote or super remote xt37 to generate this option.' VVDI2 says wrong remote type. It's defiantly an xhorse super remote I'm using. Been using KeyDIY if ever needing these, but would like to know what's the deal with the xhorse variant here.
edit: realized was using super remote and not wireless remote.
Hello
my tool ( first key tool ) start with "safe protect" message i can't use it ! >> internal memory is full
& after use update kit (1 repair ( 2 update ... tool is dead
Do you know new tool able to renew NCF chip for new keys ?
parhamkiani (18th April, 2024)
hi friends
i have problem to update dolphin II xp005L
download new firmware but no way to install it ....
and more no way to decode A5 key ... always crash during decoding it
any idea to update with success ? maybe is beug to decode A5 key to cut it fine
last time always i must dremel PSA keys because not working in doors ...
Where you found universal duplication in menu ?
Check the screenshot.
Spoiler: it does not mater which machine model you will chose - it is always on the same place.
peko (25th March, 2024)
yes is this menu cut bad 2 psa keys
and now no way to decode A5 key, always crash decoding using "chanel track"
i made again all calibration but no way
Я тоже выбираю универсальное дублирование
I have problem with my VVDI KEY TOOL Can't Upgrade and stay Like this
can anyone help me please
today seem lot of beug with internet so maybe server is out today
@ Anass GM
Few months ago I did had similar problem but with vvdi2 remote data update (and some other xhorse small updates).
The solution was instead of WiFi I used mobile phone internet connection (no wifi).
It did worked perfect. No problems… you can try it…
If doesn’t work it is probably server’s problem or some bug…
