Results 1 to 5 of 5
    youssef70's Avatar
    Sep 2008
    tunisia sbz
    Default Fiat ducato edc16c39 T.V.A
    hi
    need disable TVA in fiat ducato 2.3 mjd edc16c39
    HW: 0281014731
    SW: 1037391756
    Pi?ce de rechange: 51821469
    ( dtc P0386 : throtle is damaged )
    Act Tuning's Avatar
    Sep 2016
    Around
    Tva removed,
    CVN FIX Vag/Bmw
    Tuning Petrol and Diesel
    High Power Maps
    Custom Tuning Stage 3+ Hybrid
    Dsg Tuning
  3. The Following 2 Users Say Thank You to Act Tuning For This Useful Post:
    gabrilupo (30th May, 2018), youssef70 (19th October, 2016)
    youssef70's Avatar
    Sep 2008
    tunisia sbz
    Quote Originally Posted by Act Tuning View Post
    Tva removed,
    solution not ok dtc removed but lcv always in limp mode
    solved by new throtle body +wiring +fuse repair
    anyway thanks for effort .
    youssef70's Avatar
    Sep 2008
    tunisia sbz
    Red face
    Tva removed,
    are you sure solution is with TVA disconnected ?
    Act Tuning's Avatar
    Sep 2016
    Around
    Solution is tested on many c39 ecus 100%, unless you have problem in the car as you say, fuse wiring, all ok.
    CVN FIX Vag/Bmw
    High Power Maps
    Dsg Tuning
