Results 1 to 8 of 8
    Brayn's Avatar
    Oct 2015
    Colombo
    Default SsangYong key program
    Hello
    SsangYong Rexton key lost. When I going to program keys it ask security code
    Ecu code is 9F4540E5
    Can I get security code please??
    Sent from my C5502 using Tapatalk
    Sep 2013
    garage
    try immo off if is diesel read spi eeprom an post for immo off
    Brayn's Avatar
    Oct 2015
    Colombo
    Yes this is diesel. 2008. Can immo off this modle?
    If yes what I should read? Engine ecu spi chip?
    Brayn's Avatar
    Oct 2015
    Colombo
    Key program succefull via G scnner
    No need security code for that
    dragoshu's Avatar
    Aug 2016
    Dacia
    I have Musso A1615454732 ecu and car it AKL Can sombody add transponder in dump or turn off immo
    If I help you dont forget to push thanks button
    ypiter's Avatar
    Jan 2012
    RUSSIA
    ypiter's Avatar
    Jan 2012
    RUSSIA
    gasoline ecu - m48 chip, add with tango
  8. The Following User Says Thank You to ypiter For This Useful Post:
    dragoshu (1st July, 2020)
    dragoshu's Avatar
    Aug 2016
    Dacia
    I have made with tango clone and not able to start,zedfull dusnt have it,Ill tri with Efi.This it the reason I have ask if sombody can edit dump and put this transponder inside .
