Hi Dominik, what equipment do you use for read this ecu ?
Best regards.
Dragon
FGTech by OBD .
dragon100 (21st October, 2016)
dominik as i remeber you tuned some cars here with good feedback, what the problem in this file, you want i give you map location to tune it ??
CVN FIX Vag/Bmw
Tuning Petrol and Diesel
High Power Maps
Custom Tuning Stage 3+ Hybrid
Dsg Tuning
Act Tuning , if You can .
Here maps list :
Torque - 06E48C 20x1
06E618 20x1
Boost Pressure - 050F84 16x16
051184
051384
Driver wish (fact) - 04C1FE 16x16
04C3FE
04C5FE
04C7FE
NM to fuel - 0537E4 16x16
053FE4
CVN FIX Vag/Bmw
High Power Maps
Dsg Tuning
Hi, Act Tuning
You have damos file for thise ECU?
Fiat Scudo 2.0 HDi SID803A
5WS40899B-T
SW:9667115080
I need help to remove the DPF with disconnect sensors.
OBD file read FGTech.
Pike, i dont have damos for this, i work with other approch, do you want me to remove dpf from your file ?
CVN FIX Vag/Bmw
High Power Maps
Dsg Tuning
stanislav georgiev (30th November, 2016)
Here is dpf removed,
CVN FIX Vag/Bmw
High Power Maps
Dsg Tuning
pike (29th November, 2016), stanislav georgiev (30th November, 2016)
You can dissconnect all,
CVN FIX Vag/Bmw
High Power Maps
Dsg Tuning
pike (30th November, 2016)
