Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
Thread: BMW MULF repair
  1. #16
    Aug 2010
    I cant download too(((
  2. #17
    May 2016
    i upload files~
    if help ,~ press thanks button,
  3. The Following 9 Users Say Thank You to rainbows528 For This Useful Post:
    HAMS (21st July, 2020), jakim8 (29th March, 2020), moserts (15th January, 2020), okm (2nd September, 2019), Robon (8th October, 2022), Romas002 (5th September, 2019), Sazeck (4th February, 2020), stevebbb (25th January, 2020), zero9 (3rd March, 2019)
  4. #18
    Top Poster MCNexo94's Avatar
    Sep 2009
    Please i am have same problem i have 2 MULF no detect in ista just i am read diagnostic using ISTA D after diagnostic ECU MULF dead same problem for old version ISTA for bug FRM3.
    I have one programmer Batronix BX48 Batego II and other programmer JTAG Smok and other programmer is possibel post file for connection wire direct in MULF or PINOUT please
    Thanks.
  5. #19
    May 2018
    Please delete this reply.
  6. #20
    Jan 2020
    Hello, my BT module just went to crap, cannot be turned on, and cuts out radio.
    Took it apart, PCB looks fine, and i saw that the 28F128J3C needs to be resoldered and reprogrammed.
    Funny thing is, i don't have that chip/flash, the one that i have is: 128J3C150.
    Is there any chance that this can be flashed with the same code?
  7. #21
    Jul 2020
    Sorry to open up an old Post.
    I have a problem with my bmw e91, the Bluetooth does not work, so I dissasabled the mulf because I have read that resoldering the Flash could help. My question is: can I use the software for the 28F128J3C Flash also for my 28F128J3D75 Flash?
    MULF is a 2006 with product number: 84.21 9 - 123290 - 01
  8. #22
    Jul 2020
    Did you try it out? did it work?
  9. #23
    Aug 2022
    Netherlands
    Like to try this too.
    Do you program it in a BGA socket or on the board itself?
    Quote Originally Posted by markmich View Post
    99,9% the damage of the content flash 28F128J3C. Only soldering never helps. Checked on a dozen or so pieces.
    I enclose the file with the new program. Will heal every MULF. Beeprog in this will help.
    I think, that I helped.
