For read and write use ABRITES
Hi to all.
Have been searching for good chip tooning tool for my ECU. Car is PSA, Citroen C5 2.7HDI with Siemens SID201. Have to get DPF and EGR off. I have Lexia for faults etc.
Lot of contradictory info on what tool to buy that is able to read and write data.
Was thinking of V54 FGTech Galletto 4 Master, can someone with same ECU to confirm if this can be used to R/W? It seems read is via BDM and write via OBD?
Noob here asking basic questions
DPF/FAP off, AdBlue off, EGR off, Throttle valve off, Flaps off, DTCs off, Lambda off,
I have found this Siemens SID201 at MPPS V18 supprted list
Can, No K line,,,
So dont think work Citroen,
Galleto v53 or Ktag do this via bdm, kess dont read this ecu via obd only write.
My option for you is buy i/o terminal basic
That tool can read and write FULL via OBD it is very good!
So it seems Abrites and I/O Terminal can read and write via OBD but just for little flashing, plugins for those are a bit pricy.
Galletto V54 and Ktag can read only via BDM and both can write through OBD. Price for these are more suitable but requires bit more manual labor.
Have to think about this a bit, with Abrites and I/O I could MAYBE do some work for customers in future without removing ECU IF I get a hang of this... And that's a big if.
This is my suggestion to you,
If you doing ECU first time , I would always read BDM, this way you are safe and have back up. After this you can see what happens via OBD .
Sometimes via OBD it does not read or write good, then after that you are in position" please I need HELP, i bricked ECU ".
Need to find ECU files, or ECU ,program immobilizer and etc. So this is 10X more job then pull ECU out and read BDM.
If you buy Abrites you can read like you read on BDM this ecu no problem
Abrites seems to be very good for this but I think I have to pass that one just because it costs too much (over 800 just fot the interface + very pricy plugin) and wasn't thinking of starting to sell any kind of flashing just yet. Don't feel comfortable braking some strangers car just yet ;D
yugo45 (30th October, 2016)
