Results 1 to 14 of 14
    BestElectrical's Avatar
    San Diego, CA, USA
    Default 2005 VW GOLF Secondary air injection delete
    Hello, Can somebody help delete secondary air injection
    2.0 VW golf 2005
    PN: 06A 906 032 RF
    0 261 208 561
    Flash memory AM29F800BB
    06A906032RF.rar
    The engine was replaced and now there is no holes in cylinder head for secondary air injection. Now getting codes and cannot fix it without replacing cyl head.
    Thank you,
    BE
    Act Tuning's Avatar
    Sep 2016
    Around
    You need to post the fault code you have, that someone can help you,
    CVN FIX Vag/Bmw
    Tuning Petrol and Diesel
    High Power Maps
    Custom Tuning Stage 3+ Hybrid
    Dsg Tuning
  3. The Following User Says Thank You to Act Tuning For This Useful Post:
    BestElectrical (1st November, 2016)
    San Diego, CA, USA
    What about readiness? is there any way to turn it off and make it N/A?
    Act Tuning's Avatar
    Sep 2016
    Around
    no, it just need to remove the dtc and thats it,
    CVN FIX Vag/Bmw
    High Power Maps
    Dsg Tuning
  6. The Following User Says Thank You to Act Tuning For This Useful Post:
    Act Tuning's Avatar
    Sep 2016
    Around
    If i remeber its should be P0410 fault, do you want i remove it for you and try, if you can get dtc
    CVN FIX Vag/Bmw
    High Power Maps
    Dsg Tuning
  8. The Following User Says Thank You to Act Tuning For This Useful Post:
  9. #6
    San Diego, CA, USA
    Yes, please. thank you a lot
  10. #7
    spychu14's Avatar
    May 2011
    POLAND
    P0410=Secondary Air Injection System
    P0411=Secondary Air Injection System Incorrect Flow Detected
    P0412=Secondary Air Injection System Switching Valve "A" Circuit
    P0413=Secondary Air Injection System Switching Valve "A" Circuit Open
    P0414=Secondary Air Injection System Switching Valve "A" Circuit Shorted
    P0415=Secondary Air Injection System Switching Valve "B" Circuit
    P0416=Secondary Air Injection System Switching Valve "B" Circuit Open
    P0417=Secondary Air Injection System Switching Valve "B" Circuit Shorted
    P0418=Secondary Air Injection System Control "A" Circuit
    P0419=Secondary Air Injection System Control "B" Circuit
    P0491=Secondary Air Injection System Insufficient Flow Bank 1
    P0492=Secondary Air Injection System Insufficient Flow Bank 2
    P2257=Secondary Air Injection System Control “A” Circuit Low
    P2258=Secondary Air Injection System Control “A” Circuit High
    P2259=Secondary Air Injection System Control “B” Circuit Low
    P2260=Secondary Air Injection System Control “B” Circuit High
    P2430=Secondary Air Injection System Air Flow/Pressure Sensor Circuit Bank 1
    P2431=Secondary Air Injection System Air Flow/Pressure Sensor Circuit Range/Performance Bank 1
    P2432=Secondary Air Injection System Air Flow/Pressure Sensor Circuit Low Bank 1
    P2433=Secondary Air Injection System Air Flow/Pressure Sensor Circuit High Bank 1
    P2434=Secondary Air Injection System Air Flow/Pressure Sensor Circuit Intermittent/Erratic Bank 1
    P2435=Secondary Air Injection System Air Flow/Pressure Sensor Circuit Bank 2
    P2436=Secondary Air Injection System Air Flow/Pressure Sensor Circuit Range/Performance Bank 2
    P2437=Secondary Air Injection System Air Flow/Pressure Sensor Circuit Low Bank 2
    P2438=Secondary Air Injection System Air Flow/Pressure Sensor Circuit High Bank 2
    P2439=Secondary Air Injection System Air Flow/Pressure Sensor Circuit Intermittent/Erratic Bank 2
    P2440=Secondary Air Injection System Switching Valve Stuck Open Bank 1
    P2441=Secondary Air Injection System Switching Valve Stuck Closed Bank 1
    P2442=Secondary Air Injection System Switching Valve Stuck Open Bank 2
    P2443=Secondary Air Injection System Switching Valve Stuck Closed Bank 2
    P2444=Secondary Air Injection System Pump Stuck On Bank 1
    P2445=Secondary Air Injection System Pump Stuck Off Bank 1
    P2446=Secondary Air Injection System Pump Stuck On Bank 2
    P2447=Secondary Air Injection System Pump Stuck Off Bank 2
    VAG
  11. The Following User Says Thank You to spychu14 For This Useful Post:
  12. #8
    Apsik's Avatar
    Mar 2015
    just behind you
    Your file is a bit different to what i'm used to (1.8T) but SAI should be OFF.
    Readiness monitor is set to unsupported (VCDS should show PASSED).
    However you may have cold start issues because I did not found SAI flow related maps.
    Can't find ESCONF either to fix the circuit related DTC's for pump and relay, but will try to do it later.
    Test the file and I'll add some improvements later
    06A906032RF (VW Golf 4 (SAI OFF) - 371723).zip
  13. The Following User Says Thank You to Apsik For This Useful Post:
    BestElectrical (2nd November, 2016)
  14. #9
    San Diego, CA, USA
    Default Secondary Air Injection
    Thank you for the help.
    Here is what I get when I write this dump back into the module.
    SAI is still on. I can hear it when I start the car and it is still failing the readiness.
    Any other ides?
  15. #10
    Apsik's Avatar
    Mar 2015
    just behind you
  16. The Following User Says Thank You to Apsik For This Useful Post:
    BestElectrical (3rd November, 2016)
  17. #11
    kinketotua's Avatar
    Apr 2016
    Europe
    here you can try these
    unplug pumb
    --> Attachment 407929
  18. The Following User Says Thank You to kinketotua For This Useful Post:
    BestElectrical (4th November, 2016)
  19. #12
    San Diego, CA, USA
    Quote Originally Posted by kinketotua View Post
    unplug pumb
    Thanx for the help,
    After writing file back to module, SAI still not set/failed on readiness.
    Do you have any other ideas?
    Thank you
  20. #13
    kinketotua's Avatar
    Apr 2016
    Europe
    sorry friend..I dont have another solution to disable these system. good luck
  21. The Following User Says Thank You to kinketotua For This Useful Post:
    BestElectrical (5th November, 2016)
  22. #14
    Apsik's Avatar
    Mar 2015
    just behind you
    OK 3th attempt
    MSLUB and CDSLS 00'ed
    Keep the SAI relay pluged in and let me know.
    06A906032RF (VW Golf 4 (SAI OFF V3) - 371723).zip
