Edc15c39 ???
Are you sure?
Bdm is not possible for edc15...
Anybody have pinout for galletto and EDC16 BDM??
I am trying to read ecu...still get error in galletto SW. maybe chiness adapters? I tried to connect it manually from google pinout for BDM galleto but still get error.
I used this pinout:
http://img2.uploadhouse.com/fileuplo...7029c63d9c.jpg
GND, 12V, 12V ign connected from external sources . (GND not connected to galletto) only to external source.
I tried it without adapters...directly...no result.
tanks
Edc15c39 ???
Are you sure?
l have 2 fgtech eu clones and they are crap on bdm , work fine on edc17 and pcr2.1 but not well bdm ! l hate the the way you have to power it too ,very easy for noobs to place wrong with power on and burn ecu , bdm100 or ktag never fail
saying that got me out of trouble on a volvo edc16 worked over kline
I've galletto2 and galletto4. They work good...
So my question is..what with GND... Connect it to galleto pin 5 or to external power supply as ground for 12V and 12V IGN? Because there is only 1 ground on BDM pads... But I need 2 ground points one for galletto data reading and one for supply.
thanks!
this link can help you:
http://blog.obd365.com/2014/08/15/if...-galletto-v54/
I know this adapters..but anybody know direct connection wiring? Where to connect ground?
Everyone is a noob at the begining.......or someone born as chipmaster? .....I hate this words about noobs and etc....
Yes but sorry my english probably misunderstanding. Now I have answer..ground on pin 3 and 5 galletto must be connected to ground on BDM pads + this ground is same for external power supply so paralell connection. This was my answer.
About chiness adapters...yes you can use them If you have some spare ECU, because my adapters which comes with galleto have faulty wiring...!!!!!!
Post a high resolution pictures (both sides) of your faulty BDM adapter for Bosch ECUs, so we can see with our eyes.
Regards!
