Results 1 to 14 of 14
Hybrid View
    Top Poster + Edc17tricor3's Avatar
    Jan 2015
    Default W906 2015+ SKC star key calculator error
    Hi, I have a problem with sprinter w906 2015 year.
    Mcu mask is always 0L01Y But when i open dump with SKC calc it give me an error "loaded dump not correct"
    I tried to generate keys dump with vvdi mb tool and it work (key work and actived)
    Someone know if there is a sw working with offline generator that work good with this new thype of dump?
    Read with r270, with xprog and with vvdi prog always same file (exactly the same)
    Professional Chiptuning Service
    Edc17/Med17/Mev17 Special services
    Multiple Immo Solutions
    Nov 2009
    workshop
    2015 dump new for skc,check version datum
    Jan 2015
    Quote Originally Posted by mercis View Post
    I use skc 1.0.1.2
    Dump is w906 year 2015
    It show me "dump not correct"
    If I load the same dump on vvdi mb prog it generate key correctly
    Jan1980's Avatar
    Nov 2014
    How did you read the mcu ?? For example, if i load a dump with my genuine AVDI, i cannot open in SKC, too. Dump is crypted. I can only calculate keys and make new keys with AVDI..
    Nov 2009
    workshop
    skc old for 2015 dump
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by Edc17tricor3 View Post
    I use skc 1.0.1.2
    oh god so much not usefuls post's....show first your dump, then we can take a look, why not loaded correctly in your SKC
    many thanks to friend kevfield
  7. The Following 2 Users Say Thank You to daxxer For This Useful Post:
    mercis (7th November, 2016), volismb (7th November, 2016)
  8. #7
    Jan 2015
    Quote Originally Posted by daxxer View Post
    Added to first post
  9. #8
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Added to first post
    by me worked in SKC without any problems, I try to use more SKC versions from oldest 1.0.0.5 what i have to newest 1.0.1.2 and all success
    ...but need little reworked before read it in SKC the all data are the same as in anyone W906, but little moved to another adress in eeprom memory
    what tool you use for reading from MCU eeprom ????
    reworked dump here :: W906.DK.rar
  10. The Following User Says Thank You to daxxer For This Useful Post:
    Edc17tricor3 (7th November, 2016)
  11. #9
    Jan 2015
    You are the best!
    Infinite thanks!
    I read with r270, xprog, and vvdi prog same dump
  12. The Following User Says Thank You to Edc17tricor3 For This Useful Post:
    daxxer (7th November, 2016)
  13. #10
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    You are the best!
    Infinite thanks!
    i'm sure not the best, sure exist somebody who can be better
  14. #11
    Jul 2009
    Hello friends can you help me too I have dump from spriter eis 2015 with mask 0l01Y and my skc say dump not correct can you rework dump?
  15. #12
    Jul 2009
    I did self base on example in post thx
  16. #13
    May 2016
    Default damp
    Hello. Same problem. Help SKC does not read the working dump.
    Volkswagen crafter 2008. mask 0L01Y. Edit my dump. So that I can read it with the SKC calculator. What needs to be edited so that the dump is normally read by SKC. Thanks. How to upload a file to a website. Explain to the fool.
    pull out the key files, someone help!!!!
    Thanks.
  17. #14
    rob h's Avatar
    May 2011
    Skc does MB.
    Not Vag. And no US MB with Crafter lookalike eis.
    You will need a tool, that can add transponder direct to dump.
    Or a dump decoder. So you can precode transponder with cs, and program these with pin.
    Have a look on DK, and you will see.
    You could post dump, and maybe someone will help
