Page 1 of 3 123 LastLast
Results 1 to 15 of 36
    Top Poster crowbareight's Avatar
    No fixed abode!
    Post JD diagnostics needed !
    Wanted !!
    John deere Agri machines diagnostic software & what ever else I can get my paws on !!
    Member DonL's Avatar
    Canada
    PF-Diagnose can read John Deere and has John Deere Database of fault code definitions
    no advertising !!!
    DK Veteran hercamp's Avatar
    also with deutch 9 pin and j1939 prot.
    u can connect with dearborn DPa 4 plus and read codes with dearborn diagnostic..is inside of driver installer disc.
    other way only posible with service advisor of jhon deere with agri disk inside.
    Senior Member colh's Avatar
    Hi Hercamp
    Have you seen the connector on the john deere version of nexiq ,is it an oval shape or is it still a deutch type.
    Regards col
    Member fixacar's Avatar
    canada
    Quote Originally Posted by crowbareight View Post
    Wanted !!
    This is the only guy that i know who has JD AG.
    John Deere diagnostic tool software cabel, Interface, adapter for diagnostic software - www.o2epc.com
    same deutch 9 pins works with other square adapter of 6 pins ...special one that is same of jd excavator ...
    Quote Originally Posted by hercamp View Post
    Hercamp do you mean that both Ag and Industrial use square 6 pin or does one use deutsch 9 pin or is there an adapter from 9 pin to 6 pin square.
    Regards Again col
    Feb 2009
    Quote Originally Posted by fixacar View Post
    There was a set of AG dvds around for
    8_2009.
    Installs JD_SA version 2.8.205.
    I have only the install_dvd1 uploaded.
    Requires XP sp2 with net frameworks 1.1
    and 2.
    Best to use adobe reader v9 with JD_SA.
    I only started playing with it recently,
    so dont know that much about it.
    Cant upload the rest just at moment sorry.
    Maybe you can get from here:
    http://topstaramb.forumer.ro/automotive-software-autocamioane-f1/john-deere-service-advisor-v-28-t319-30.htm
  9. The Following User Says Thank You to mozzie For This Useful Post:
    dupisa (20th April, 2020)
  10. #9
    Junior Member juanje's Avatar
    thanks for the dvd 001
  11. #10
    canada
    This AG is good from autocamione.
    It works well with CF as an upgrade.
    You can edit SA ini for longer expiry before saving to disk.
  12. #11
    Oct 2010
    any ideas on the edl /usb link to use? im tempted to by the nexiq usb link as it is the same product number as on the jd edl link but i know what jd is like and im convinced that it wont work and dont want to waste money to find out! anyone verify that the nexiq usb link does work with service advisor? please
  13. #12
    Top Poster sca.net's Avatar
    Me too. I want to know...
    If Service Advisor 2.8 works with Nexiq USB LINK.??
    Regards.
  14. #13
    Quote Originally Posted by sca.net View Post
    Regards.
    Tried today 9300 4x4 could not find 9 pin connector where manual says it is supposed to be.Should be under rear of cab or behind cover on rear of cab that covers all control modules.So sorry I still cant help any of you hope to try again on something else in a couple of days.Regards to all col
  15. #14
    Default Question about Nexiq USB Link
    I Hope you find out my friend, it's a valuable information to decide if to buy a nexiq usb link or to move to magikey or something else.
    Big question...
    DOES SERVICE ADVISOR 2.8 WORKS WITH NEXIQ USB LINK?
    Anyone else can help?
    Thanks.
  16. #15
    Big question...
    Thanks.
    I too really want to find out.I would like to know if it does not then if buying JD EDL wether it will work like normal nexiq on other applications if you use 6 and 9 pin deutsch nexiq y connector.If nexiq does work then need someone to do pinouts for the EDL Y lead to use all functions of SA.Hope we can answer some questions soon.col
    Just found early 9300 uses lucas ECU and has 6 pin inline weatherpack connection .Maybe with a pinout of both 9 pin deutsch to magikey and 6 pin weatherpack to magikey we may get answer to using Nexiq.col
