Pin is 4760 or 0674.
Dear Friends.
This 2012 Peugeot Bipper does not start the engine after the accident. The motor rotates and turns but does not start. I have a dtc in ecu that says: Communication fault with the BSI and the engine control calculator locked in crash mode.
Would you be so kind as to provide the pin code of the BSI? What would be the procedure to restart this vehicle? No have gas pressure, no spark or pulse of injection.
thanks for your comments
Best regards.
Dragon
Try cleared file. Find inertia cut-off switch and push, sometimes near the shock absorbers under the hood.
Best regards.
Dragon
achaccha (8th November, 2016)
Good afternoon friends. After cleaning the crash of the airbag the problem persists and I have a message on the dashboard that says "FPSon" and has no gas pressure, there is no spark or pulse of injection.
Can someone tell me where the inertia button of this vehicle is located?
Hi friend
If u have turn signal flashing when u put ignition in position 2, is like a fiat doblo system
try this:
turn ignition key to MAR
turn on right turn signal
turn off right turn signal
turn on left turn signal
turn off left turn signal
turn ignition key to STOP
Cheers
Press "THANKS" button. just one click, CHEERS
achaccha (9th November, 2016), gokhanusta (9th November, 2016), rossi1000rr (4th December, 2016), Zmann (9th November, 2016)
