Hi, this your file - egr off
mascot 3.0d_egr off_chk ok.rar
Test and report
password in PM
Good luck!
engine replaced with another one. now the egr connectors are not matching, and also the mechanics of egr is totally different, ecu don`t have egr position feedback information.
have less power than normally, and have DTC DF084 CO.0 = egr valve position sensor circuit, open or short to ground. another multi brand tester reading DTC 0486.
please help at least with the DTC.
THANKS!!!
Test and report
password in PM
Good luck!
felix_fetche (14th November, 2016)
Is not working, DTC is still on.
Please help.
Egr removed,
CVN FIX Vag/Bmw
Tuning Petrol and Diesel
High Power Maps
Custom Tuning Stage 3+ Hybrid
Dsg Tuning
felix_fetche (18th November, 2016)
ACT`s file is okay from the point of view of EGR DTC.
EGR errors are vanished now.
But i still have a problem, original engine index was ZD3 604, now is mounted one ZD3 with index 606.
ECU detects that the intake manifold flow is different, and it behaves like this:
-when engine is cool is accelerating even to 4500RPM,
-when it gets hot over 50-60grd*C maximal RPM is limiting to 2750-3000RPM with lot of white smoke.
-if i pull off MAF sensor connector, max RPM is 1500RPM and with smoke big quantity.
I believe that next step is to modify software to work without MAF.
Is possible to modify it in this sense?
THANKS!
