swiftec can remove limiter
- BOSCH EDC15C6 (EEPROM)
https://www.vcpowerteam.com/products...emoval-module/
someone can share solution
thx
thx
star diagnosis obd,easy
need remove total or set 140-160 km/h
I will ask you again... how much is the speed limit now?
90, 100...???
now is 88km/h
Test this...
Regards!
wflseba (10th November, 2016)
Now the limit is 40km/h
eeprom after 40km/h
How you read the real speed of the vehicle... with diag scanner from the ECU, or with your eyes from the tacho?
In the ori dump i think the speed limiter is 89km, in the seccond - 35km.
Any way... now i'm wait one friend to make the speed limit remove with Swiftec...
Be patient...
SOLVED write file from another ecu
address from 1d0 to 1d4 change to 02 02 00 ff ff(virgin)
I do not know what the speed limit is now but was driving 140 km / h
i think solution is good
any way thanks friend
attachments file to compare
161 in this file...
So i was on the right way, but obviously there is and checksum, which i don't know how to do...
BTW, i hope, that the codings of the ECU are the same, but... without the STAR, you never will know.
You must to have this tool, mate!!!
Regards!
clauberty (6th October, 2022)
