Here you go.
Here you go.
__________________
If You Like My Post
Please use the button on the LEFT side and the button on the RIGHT side.
Tuning, EGR, DPF, AdBlue, DTC, TVA, Speed Limit, Immo...
he asked for dpf off
and your file is EGR off or it's just a name?
the man has a point
CVN FIX Vag/Bmw
Tuning Petrol and Diesel
High Power Maps
Custom Tuning Stage 3+ Hybrid
Dsg Tuning
Attention file not original
Bad Tuning !!!
Ecu powered, Dtc, Egr, Dpf, Throttle, Flaps, Lambda, Hotstart, AdBlue, Evap, Nox, Speed limiter, Dynotest development.
pike (13th November, 2016)
__________________
If You Like My Post
And be aware that ECU it's probably unlocked, since it have modified file. So if you will unlock it again, you will actualy lock it back.
What tool do you use for Read/Write ?
__________________
If You Like My Post
smirnoff_rules (13th November, 2016)
I receive car from other service...and ecu unlocked
read with galeto and when put this file car not start.....
before read ecu I read eeprom and save
now i put ori file and ori eeprom and car start...
now will try to write your file and report...
can anyone post ori file?
to write original and then dpf off...
when receive car i read eeprom and save ....and i read file via obd without unlock eeprom....eeprom unlocked from other people....
I try to write dpf off file and galeto send error ....not writing...
can anyone check eeprom file ...
what i need to do?
Do you have KESS V2?
Or better contact me on Skype. Will be faster to talk
BR
__________________
If You Like My Post
now i ordered..and tommorow when receive i will write and report...
