Results 1 to 15 of 18
    Jun 2012
    Cool Peugeot Bipper 1300 hdi Marelli MJ8 DF ecu
    Hi Need to Remove DPF from this Ecu had someone try earlier but i still have 2 x DTC
    1 code is Exhaust temp other is Particulate Filter ,
    i get codes shortly,
    Thanks help Professionals
    Please Manual soloution, Not Volta !!
    Jun 2012
    Have 2 codes
    P2081 Soot DPF,.
    P1564 Exhaust Temps sender (Permanant)
    Cheers
    Jul 2011
    Default Hi
    hi. dpf off, dtc off.
    pass.pm
  4. The Following User Says Thank You to draganelektricar For This Useful Post:
    pulsar2000 (14th November, 2016)
    Jun 2012
    Thank you My Friend, I test and Report Tomorrow, Cheers
    Jul 2011
    ok. my frend..
    Jun 2012
    Quote Originally Posted by draganelektricar View Post
    ok. my frend..
    Hi sorry to say this solution not work.,..
    no codes after write, but goes into limp mode wont drive past 3k rpm
    and dpf light comes on,
    any ideas ??
    i get codes now, need to sort this asap,,,
    Jun 2012
    Anyone have a solution for this ? Dragan your mod, van has no DTC but does have Limp mode when we drive and DPF light comes on after 10km,
    I need a good solution NO limp, NO DTC cheers
    pike's Avatar
    Sep 2013
    Hi.
    I think, that a little bit later, you will need to EGR off also.
  10. #9
    Jul 2011
    put that replaced dpf.
  11. #10
    Jun 2012
    Ok if need be EGR off also ?
    I just need out of Limp mode and no DPF light please, Theres no Codes, I appreciate your help draganelektricar,
    I try Disconnect and Connected Pressure sensor,
  12. #11
    Jun 2012
    Quote Originally Posted by pike View Post
    Hi.
    How u mean is no poss just DPF off, So EGR also ?
    can you explain
  13. #12
    pike's Avatar
    Sep 2013
    After DPF off, after a while you may come to the problem with egr valve, possibly.
  14. The Following User Says Thank You to pike For This Useful Post:
    pulsar2000 (16th November, 2016)
  15. #13
    Jul 2011
    I'm sorry I have not seen for EGR.
    pass.pm
  16. The Following 2 Users Say Thank You to draganelektricar For This Useful Post:
    pike (16th November, 2016), pulsar2000 (16th November, 2016)
  17. #14
    pike's Avatar
    Sep 2013
    Is there any test results?
  18. #15
    Jul 2011
    results.
