Results 1 to 8 of 8
    Fec001's Avatar
    Apr 2010
    Default W203 220 CDI swirl flaps off
    Hi!
    Please switch off swirl flaps in this dump. I have DTC P1189 and limp mode all the time.
    Jun 2010
    limp is cause the m55 motor.remove flaps and istal one used m55.easy.
  3. The Following User Says Thank You to zoyzoyni For This Useful Post:
    Fec001 (16th November, 2016)
    konq100's Avatar
    Oct 2013
    Sofia, Bulgaria
    Use 1K resistor - Simple and effective 100%.
  5. The Following 2 Users Say Thank You to konq100 For This Useful Post:
    bobolin4o (16th November, 2016), Fec001 (16th November, 2016)
  6. #4
    Jun 2010
    did you test m8?1k work as emul?
  7. #5
    Fec001's Avatar
    Apr 2010
    Quote Originally Posted by konq100 View Post
    Can you tell, where I must put the resistor?
  8. #6
    Act Tuning's Avatar
    Sep 2016
    Around
    Best way do it with flash 100%, why to search new projects,
    CVN FIX Vag/Bmw
    Tuning Petrol and Diesel
    High Power Maps
    Custom Tuning Stage 3+ Hybrid
    Dsg Tuning
  9. #7
    Fec001's Avatar
    Apr 2010
    Can you help with flash solution?
  10. #8
    konq100's Avatar
    Oct 2013
    Sofia, Bulgaria
    Quote Originally Posted by Fec001 View Post
    Solder 1K resistor betweеn positive and signal wire. Don't forget disconnect connector.
    Solution already tested and for me is best efficient and cheap way to stop flap.
    Chears.
  11. The Following User Says Thank You to konq100 For This Useful Post:
    Fec001 (17th November, 2016)
