    Apr 2016
    Default R270 2K79X CAS2 Unknown pin error help for all members
    Hello there!
    Yesterday i had this CAS2 and spent half day resoldering wires,and my R270 keeps saying: unknown pin error... I think most of you had same problem...So i crossed my fingers and skipped pin check, and it reads ok.
    IF YOU HAVE UNKNOWN PIN ERROR,DOUBLE CHECK YOUR SOLDERING AND SKIP PIN CHECK!!!!
    It will read your mcu without problems!!!
    I hope this helps!
  2. The Following User Says Thank You to alkaskad For This Useful Post:
    Levanime (11th July, 2017)
  3. #2
    tehnosoftex's Avatar
    Romania
    Or you can connect the clock pin on the mcu directly and not on the quartz.
    Dec 2010
    IMG_0308.jpgI hope it worksLuck
    Apr 2016
    Did you connect MOD B? At back side of board?
    Dec 2010
    Quote Originally Posted by alkaskad View Post
    I'm not very sure, I do not think so
    Apr 2016
    Here is R270 diagram for CAS2. Check back side.
