l know its has tricore TC1797 same as edc17c10 and l know mmps reads that but if it has the patch to unprotected files l dont know
100% need 13.8 some even 15
Anyone know if Fgtech works on this ECU,
its a 2013 Car, Sid208,
read some reports saying FGTECH doesnt work on Fords, although will work sid 208 other Makes other than FORD,
dont suppose new MPPS v18 covers ?
Also needs a Decent power supply Correct ?
Anyone info please and Cheers
pulsar2000 (18th November, 2016)
Hoping someone has some good info, got one coming in soon, Got kess and dont think Kess covers on boot mode this ecu,
if need be have to get a K TAG again, to cover this ecu,
P,s Smirnoff, Nice touch on the Photo, Bit of chinese Copyright Protect,,,, LOL
l have looked through all my stuff and only ktag shows it m8 in transdata , mpps/kess/fgtech checked, if you where around Birmingham you could borrow it
I did one of these vehicles approx 2 months ago using ktag. Worked perfectly. The hardest part of the job was removing the ecu from vehicle. It's located drivers side footwell and has security bolts holding it in. A right pain to remove!
if this post was usefull
please press
the thanks button
pulsar2000 (22nd November, 2016)
i make a 5\6 cars with sid 208 and use x17 tool.
Reggards
all orginal tool read ford with sid208 k-tag, x17, galetto
FILE SERVICE
replied m8 .................
smirnoff_rules (30th November, 2016)
You do so many cars, i don't get why you are still using clone tools!
Pro VAG Petrol Tuning | Pro DPF Removal | MED17 TPRot Removal
all org tool support ford sid208 but which support PEUGEOT BOXER SID 208 ???
PSA sid208 is not possible to read for this moment .
Sent from my HTC One A9 using Tapatalk
