I have read write this ecu with fgtech without problem.only by bootmode
Hello! I'm having trouble reading this Ecu by bootmode with Kess V2 and Ktag. Is the bootmode legend of the ksuite correct for this ECU? However by OBD it reads without problems. It is possible to write OBD this ecu. Thanks
HW 2747R
SW 1037540041
Thank you
Car28th (22nd November, 2016)
Friend your soldering and protecting PCB looks really poor. ECU was not device for 10 dollars. I recommend safer use.
Anyway great, thanks for photo for community
All brand FileService - Custom - remapping company
POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
| Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
Thank you very much! It is not possible to write by OBD with Kess V2 Euro? The OBD reading although partial is correct. Thank you
