Results 1 to 11 of 11
Thread: BDM100 Help
    Dec 2010
    Default BDM100 Help
    Hi guys,
    With a bit of faffing about I have got the BDM100 that arrived from China the other day, to kind of work on windows 10 x64... now I am not sure if I am on the latest CMD version possible... so perhaps someone can let me know? I generated a licence to avoid using the loader which seemed flaky and would only let the program run after deleting the log file.
    Now, occasionally when you get these BDM all in one files. I was under the impression I would be able to export each part of the file from within the CMD software but I can't seem to see an option. Perhaps this is only when you have made the read yourself?
    If anyone can help with my queries it would be much appreciated.
    MPPS Standalone Master, Magpro Base + X17, Dimsport New Genius, Piasini, Galletto V53, Kess V2, K-Tag, Trasdata remapping tools | OP-COM, VCDS, Fiat MultiECUScan, Ford F Super, Renault CAN Clip V124, INPA/NCS Expert + others.
    baltazar3's Avatar
    Andromeda
    Quote Originally Posted by poxxxy View Post
    Hi guys,
    Click on Export and see a miracle :-)
    '" live and learn........ if you wont ....you ain't "
    _______ . ____ . __ . __ . _______ . __ __ __ ... ---
    If my post was HELPFUL please push THANKS button
  3. The Following User Says Thank You to baltazar3 For This Useful Post:
    poxxxy (25th November, 2016)
    Jun 2012
    Quote Originally Posted by baltazar3 View Post
    Exactly What he said
  5. The Following User Says Thank You to pulsar2000 For This Useful Post:
  6. #4
    Aug 2013
    I got one from China and it's not responding. I changed the Transistor and Relays, no luck
    Jun 2012
    Only works when pins on correctly the ECU, u realise this ?
    it wont work otherwise, so unless your in a position to read ecu, pins on correct, the prog wont run
  8. #6
    Dec 2010
    Lol... not sure how I missed that! .
  9. #7
    Dec 2010
    So... how do I get those tabs to show? Ii'm not even sure how I got that to show... all I have at the moment is a tab with OBD 2... not the single file etc that I had screenshotted there. Maybe that was the problem I was having...
  10. #8
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    l had to put my windows 10 into test mode to install the drivers right for bdm100 to work
    http://maxedtech.com/about-testmode/
  11. The Following User Says Thank You to smirnoff_rules For This Useful Post:
    pulsar2000 (25th November, 2016)
  12. #9
    Jun 2012
    Windows XP works Perfect !! hence why i got so many bl00dy Laptops LOL win 7 MPPS v18 latest edition
  13. #10
    Dec 2010
    Right... seems the cmd software was seeing the interface as an OBD programmer. Not a BDM programmer... this was because i'd manually installed the fg tech drivers reported to work with windows 7 x64 through the have disk method. By waiting for my driver list to populate and then using the amt-cartech software. I am able to load into that page with the interface connected. Not sure it will work though. Can't say i'm hopeful . Need an EDC16 ecu to test it out on now!
    Here is the page I kept getting to which was puzzling me...
    I tried loading up some apparently full bdm files but never got the chance to export each component from within the software so never got to test that function I was looking for .
  14. #11
    Aug 2013
    Quote Originally Posted by pulsar2000 View Post
    But
    no relay clicks and was checking voltage on the Pins and no 12V.
