your file is OK
8E0909518AK 1.8L R4/5VT 0006
1037378109
TunerPro definition file was made for:
8E0909518AK 1.8L R4/5VT 0003
1037368072
Your software is newer than the one the definition file was made for.
Hello I read a me7.5 ecu today with a galletto clone.The ecu info looks good.It was read in boot mode.However.When I input the bin into winols or tuner pro with the definition file I have for this ecu none of the values make sense.Can anyone tell me why??Ecu is a 518AK.
This is the file it read.Can anyone tell meif its a good read or not??Also does winols use the same dll to correct checksum for me7 and me7.5??or a different dll??0261208230 1037378109 backup 518AK.rar
your file is OK
1037378109
1037368072
AudiS4 (29th November, 2016)
Does that mean I will have issues using that xdf???I was looking at Krkte value and what it reads is 5.4966 but I was under the assumption it should be much much lower around 0.1039??Also Can I flash a lower software level into the ecu so I can use that XDF to edit accordingly??Also is the vin stored in the flash file??and immo id or is it all on 95040 and its all separate??
Ok Perfect This is what I will do.Thanks for your time.
You have a buton for thanks, he help you so much, at least click some thanks and mybe rep if it help you, but i can understand why, 97 downloads and 1 thanks,
CVN FIX Vag/Bmw
Tuning Petrol and Diesel
High Power Maps
Custom Tuning Stage 3+ Hybrid
Dsg Tuning
Good edit mate...and just in time too....take it easy please
Here you go ACT Tuning.I know you probably have a Virgin 95040 dump.This will work with me7.1 and me7.5 audi/vw vehicles.You can reflash a used ecu with this and adapt using vcds like it a new ecu.Makes things easy!!DO NOT USE THIS FOR ME7.1.1 or any other motronic systems other than what I listed.
Virgin 95040.rar
