version of
Boston Market Meatloaf
If you already have a recipe that claims to be a clone for this delicious meatloaf...you can now
toss it out, purge if from your hard drive, burn all hard copies. No clone recipe that I've found
yet -- and there are several circulating -- has come even close to the tender, tasty meatloaf you
can get from this popular chain. Don't be fooled! To make a REAL clone, first thing you've got
to do is use ground sirloin, just as the restaurant chain does. And then you need to know how to
make the special sauce that goes into the meatloaf and on top (no it's not ketchup and it's not V-
8). And there's no minced onion in there (just look at it!), or onion soup mix for that matter. So,
search no more for the perfect clone of Boston Market's tasty meatloaf. You've now got the
result of days and days of vigorous testing. Even if you don't normally enjoy meatloaf, this one
you'll be a cravin'.
1 cup tomato sauce
1 1/2 tablespoons Kraft original barbecue sauce
1 tablespoon granulated sugar
1 1/2 pounds ground sirloin (10% fat)
6 tablespoons all-purpose flour
3/4 teaspoon salt
1/2 teaspoon onion powder
1/4 teaspoon ground black pepper
dash garlic powder
1. Preheat oven to 400 degrees.
2. Combine the tomato sauce, barbecue sauce and sugar in a small saucepan over medium heat.
Heat the mixture until it begins to bubble, stirring often, then remove it from the heat.
3. In a large bowl, add all but 2 tablespoons of the tomato sauce to the meat. Use a large wooden
spoon or your hands to work the sauce into the meat until it is very well combined.
4. Combine the remaining ingredients with the ground sirloin-- flour, salt, onion powder and
ground pepper. Use the wooden spoon or your hands to work the spices and flour into the meat.
5. Load the meat into a loaf pan (preferably a meatloaf pan with two sections which allows the
fat to drain, but if you don't have one of those a regular loaf pan will work). Wrap foil over the
pan and place it into the oven for 30 minutes.
6. After 30 minutes, take the meatloaf from the oven, remove the foil and, if you aren't using a
meatloaf pan, drain the fat.
7. Using a knife, slice the meatloaf all the way through into 8 slices while it is still in the pan. This
will help to cook the center of the meatloaf. Pour the remaining 2 tablespoons of sauce over the
top of the meatloaf, in a stream down the center. Don't spread the sauce.
4
8. Place the meatloaf back into the oven, uncovered, for 25-30 minutes or until it is done. Remove
and allow it to cool for a few minutes before serving. (Top Secret Recipes)
Serves 4.
