Results 1 to 3 of 3
    twchnodictator's Avatar
    Aug 2015
    European Union
    Default Mercedes W211 DTC OFF NEEDED
    Hello mates,
    Have a problem with mercedes w211 with diesel engine.
    All the time car goes very good but sometimes check engine comes up and says p0472 and p2089. I double checked wiring, turbo, all pipes and changes sensor and plug. Car can be driven our, day, week and no light at all, but sometimes 5 times in hour. The problem is signal lost for 1 second but check comes up and stays until you won't delete DTC.
    Can somebody help me and delete this dtc from the dump? (I know it's a bad way of repairing the car but even official dealer can not solve this problem and says that problem with turbo. As I said before turbo was checked is specialized service)
    File here E280_MERC.rar
    Thanks a lot mates for your help, time and advices!
    mihaiservice's Avatar
    http://www.quick-tuning.com
    Hello
    the reason for such trouble are dpf pipe wich are clogged now ! with Star you can activate test function for both temperature sensor from dpf,the differences from up/down temperature sensor from dpf should not be higher than 50*C !
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
  3. The Following 2 Users Say Thank You to mihaiservice For This Useful Post:
    bobolin4o (30th November, 2016), pike (30th November, 2016)
    Aug 2015
    European Union
    Quote Originally Posted by mihaiservice View Post
    Hello
    DPF was removed in this car few years ago and some remap was made. Can you check this file? Maybe it's badly removed?
