Results 1 to 11 of 11
Thread: audi a3 dpf
    Dec 2013
    Bosna i Hercegovina
    Default audi a3 dpf
    greeting. if someone can help me turn off the DPF to the ecu edc 16u34 hw:0281013625 sw:1037 38 2669
    THANKS
    Hi mate!
    Your DPF OFF, Pass PM
  3. The Following User Says Thank You to bodzio012 For This Useful Post:
    dzevad (1st December, 2016)
    Dec 2013
    Bosna i Hercegovina
    Quote Originally Posted by bodzio012 View Post
    Hi mate!
    bodzio012 I did not get pass .. tank empty
    Dec 2013
    Bosna i Hercegovina
    unsolved dpf
    Send pass again
    Dec 2013
    Bosna i Hercegovina
    Friend I think the same as the original file
    a lot of smoke
    Dec 2013
    Bosna i Hercegovina
    please help if anyone solve my problem with dpf
    sida's Avatar
    May 2014
    System32
    delete your inbox
  10. #9
    You write or you compare dumps? I ask because I do dpf off by the switch
  11. #10
    Andrei2015's Avatar
    Oct 2015
    smoke is not from dpf my friend
    Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
    VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
    POPS & BANGS (Schubabschaltung, Crackles)
    on allmost every petrol
  12. The Following User Says Thank You to Andrei2015 For This Useful Post:
    dzevad (2nd December, 2016)
  13. #11
    sida's Avatar
    May 2014
    System32
    Quote Originally Posted by Andrei2015 View Post
    100% correct
  14. The Following User Says Thank You to sida For This Useful Post:
