oeyek (22nd December, 2016)
Hello ,
i have a ducati monster 796 lost key with a DIGITEK dashboard ,
Can someone helps me ?
her is the 24c16 dump and Thanx for your help
please i need key code to put manually into a T5 chip,
or a immo off file please
ducati 796 orgi file.rar
0F00 0000 0880 EC9D
Try and raport .
Remember about Thanks button
Hi mate
Please help me too!!!
I have a 796 Ducati Total lost.
Is key immobiliser in dash? I search my tango help files I don't see the same dash as my photos.
Where is the IC location?
Many thanks.
Sent from my SM-G935F using Tapatalk
Hi...I took a look at the dash...it seems that it's a fully water proofed dash. I researched and realised only tmpro can do the job. Are u sure it's a 24 chip?
Also because of this big investment (?1300) I've gotten my customer to buy a new dash with keys (used) from eBay and it just got sent over. I will try on it first and he will have an old dash with me for me to "play with", then I'll see how I make the keys for the old dash
fixanycar (3rd June, 2017)
gueswhat...... Hi please can you help fix my bike, the dash light is constantly flashing meaning no key is recognized I read the eeprom but seem can not be program either corrupt file, can you correct it?
to learn the keys you need at least the 2 black and a red which corresponds to the ECU.
Are you using the correct key learning method?
(in this memory there is no key code)
if only one key, you must necessarily put the code of your key in the file for it to work, so you must read the transponder and put the code here to allow us to modify the file
boris7589 (20th June, 2020)
Hello everyone!
Is it possible to turn off Immo in the flash of the ECU. The dashboard is damaged completely.
hello, please I need to disable the immo Ducati Monster 796 2013, if anyone can help me I would appreciate it
batmam (7th August, 2022)
