Ripping + Patching Games 0800 SSv2 Easy To Follow
Results 1 to 14 of 14
    cunny's Avatar
    Jan 2009
    The Shoutbox
    73
    Downloads
    76
    Uploads
    3
    Default Ripping + Patching Games 0800 SSv2 Easy To Follow
    Ok guys you've heard of 0800 firmware for backing up XBOX 360 games, well this is how you do it. Also this method will give you SSv2 that is prefered by all newer firmware coming out.
    Through this, I will show you how to setup to RIP a game to your PC, check and Patch it, then Burn it to Disc using a XBOX 360 DVD Drive & your PC.
    First off you will need to flash a XBOX Drive with the 0800 FW that is located in this thread here Samsung BenQ and Liteon drives have the 0800 FW but nothing for Hitachi. As the drive is not going to be used inside a console, you wont need a 'key' inserted into the FW but, if your using the drive out of your own console and not a spare MAKE SURE YOU HAVE A BACKUP COPY OF YOUR FIRMWARE - LOST KEYS WILL RESULT IN BRICKED XBOX'S. There will only be yourself to blame, you were WARNED.
    What you will need :
    XBOX Drive flashed with either IX 1.6/1.61 or 0800- Samsung - BenQ - Liteon
    Copy of XBOX Backup Creator - See attatchment
    ABGX
    Imgburn
    Ok when your drive is flashed to 0800 FW your doing to have to connect it to your PC through a Compatable Chipset (Recomended VIA 6421) Once done you will need to check its seen by the PC. Eject the tray, power off the drive, insert tray manually to half way position, wait 30 seconds, power back on. Goto device manager on the PC and scan for hardware changes ensuring that your drive is now seen by the PC
    Note that the VIA Drivers are installed, this allows the PC to see the XBOX Drive (PBS VAD6038 under DVD Drives)
    Next onto XBOX Backup Creator
    Open XBBC and select the XBOX Drive
    Insert your game and ensure Complete backup is selected, choose save location and filename, then click start
    Wait approx 15 mins until complete
    Now you have your backed up game you should now run it through ABGX
    Download and instal ABGX and set it up with the following settings
    cunny's Avatar
    Jan 2009
    The Shoutbox
    73
    Downloads
    76
    Uploads
    3
    Default Part 2
    Goto file in ABGX and save settings. You should then click the launch button, you should get a back window appear. Like this 1
    Note that all CRC's Match and that your SS version is 2. You can now go ahead and burn the game off. If you download your games, some will come with SSv1, i will also show yoou how to patch them.
    You will need ABGX in the following settings
    Now goto the ABGX Verified database here and search for your game. At the side of your game, there will be a number, click the number and then download the SS.bin and DMI.bin and save them somewhere safe. Then go back to ABGX and enter these settings
    Under the patch SS and DMI browse to the files you just downloaded. The load the .iso you want patching, click launch again. All being well you will see the following screen with similar messages
    You can the reset your settings back to how they were before and have a final check that the SS is v2 and all game CRC's match. Your iso is now ready for going to disc
    cunny's Avatar
    Jan 2009
    The Shoutbox
    73
    Downloads
    76
    Uploads
    3
    Default Part 3
    Now your iso's have been checked and patched and passed, they can now goto disc. Instal Imgburn (download from the link in post 1) an once installed locate your iso. You should have 2 files
    Double click the .dvd file NOT THE ISO. This should launch imgburn, select desired write speed. Put a DVD +r DL into the burner and click write
    There you go once completed put into a XBOX 360 to try
  4. The Following User Says Thank You to cunny For This Useful Post:
    fatmi (17th June, 2017)
    Jun 2008
    Downloads
    73
    Uploads
    Thumbs up
    Excellent Tut.
    The only thing missing is how to make a power lead for the XBOX 360 drive.
    Has anyone got a diagram?
    Then you won't have to take your 360 apart to use.
    It's then just a case of adapting for a PC enclosure.
    Frank
  6. #5
    cunny's Avatar
    Jan 2009
    The Shoutbox
    73
    Downloads
    76
    Uploads
    3
    I just use my CK3 kit for powering the drive.
    Or do you mean something like this here http://mrmodchips.co.uk/catalog/prod...8a8104e5159742
    I would also recomend buying a spare drive so you dont have to take the 1 out of the xbox to do this, ebay is best bet about ?20
  7. #6
    Jun 2008
    Downloads
    73
    Uploads
    Smile
    This is pretty good.
    Just thought with all the old 360 and pc bits I've got knocking around, I might make a dedicated machine. Doesn't have to look great. Just work.
    When I get chance I'll have a look at the power connections and if I'm able to work it out I'll post in the next week for a bodge (cheap) lead for everyone.
  8. #7
    Jan 2012
    Downloads
    Uploads
    Quote Originally Posted by cunny View Post
    Hi Cunny
    I do not want to keep opening my xbox.. which spare xbox drive do you suggest buying.
    I already have a iHass324 for burning
  9. #8
    DK Veteran martiboy's Avatar
    Nov 2008
    bonny scotland
    Downloads
    9
    Uploads
    Quote Originally Posted by madea View Post
    Hi Cunny
    If your going to be ripping games. Your best bet would be a benq or a liteon loaded with the 0800v3 fw
  10. #9
    Jan 2012
    Downloads
    Uploads
    Is this a good drive to flash.
    DVD Drive Replacement For Xbox 360 BenQ VAD6038
    and which
    CK3 kit do you suggest. and do i need a connectivity kit.
    I will not be using my xbox for power.
  11. #10
    May 2012
    Downloads
    Uploads
    why do some games work, and others dont. Forza motorsport 4 wont recognize
  12. #11
    cunny's Avatar
    Jan 2009
    The Shoutbox
    73
    Downloads
    76
    Uploads
    3
    Read up on ap2.5. Topology data. Burner max fw
    Sent from my GT-I9100 using Tapatalk
  13. #12
    Oct 2014
    Downloads
    3
    Uploads
    excellent tutorial easy enough to follow
  14. #13
    Sep 2016
    U.S.
    Downloads
    Uploads
    Default Ripping Patching Games 0800 SSv2 Easy To Follow
    Hey, listen i already used the 160K profile can i also put this on the same accountso the 160k profile this one?
  15. #14
    cunny's Avatar
    Jan 2009
    The Shoutbox
    73
    Downloads
    76
    Uploads
    3
    No idea what that is
