Results 1 to 15 of 22
    klaudio's Avatar
    Jul 2016
    Default GQ-4X will not write 93c56
    Hi forum,
    I'm trying to write a 93c56 with a GQ-X4 and is not working, does someone knows if there is a way write it?
    programmer say writing, but when verify it fails.
    cheers,
    daniersms's Avatar
    South Africa
    Try to write in 16bit and 8 bit just maybe that could be the problem
    Love this forum
    klaudio's Avatar
    Jul 2016
    Quote Originally Posted by daniersms View Post
    tried 8bit 16bit, different eeprom from list, no luck, i google that removing pin 6 to 8 might work, then again, no luck.
    open to any suggestions, this is my first time with 93c56
    trying to program a suzuki liana, got the immo 93cl66 programmed, i removed 93c56 on ecu but won't write
    you need clean chip pins
    and to confirm all pins connected. then it read and write with success .
    good luck
    Oct 2015
    try with lower voltage. i use in my programers 2.75v when no want write tham and allweys ok.
    6841707059 576F526B 57416E5453 596F55 526F6B69424152
    klaudio's Avatar
    Jul 2016
    Quote Originally Posted by m-o-y View Post
    good luck
    Done all that more than once, i even apply solder and remove just to be sure i had clean pins, I will clean my clips just to see if that is the problem.
    klaudio's Avatar
    Jul 2016
    Quote Originally Posted by rokibar View Post
    programmer does not give me option for voltage, can only test, is automatic and is using 5v, see result from test
    * Testing VCC Without Load *
    VCC 3.6V test passed (code:0x6)+
    VCC 5V test passed (code:0x1)-
    VCC 5.5V test passed (code:0x2)-
    VCC 6.2V test passed (code:0x12)-
    VCC 6.5V test passed (code:0x18)-
    * Testing VPP Without Load *
    VPP 3.6V/5V test passed (code:0x9)-
    VPP 12V test passed (code:0x8)+
    VPP 12.7V test passed (code:0x2)+
    VPP 15V test passed (code:0x4)+
    VPP 21V test passed (code:0x3)-
    VPP 25V test passed (code:0x5)+
    * Test Completed *
    Message log after writing
    Writing... Buffer
    Elapsed time: 0.92 seconds.
    Device write completed OK
    Verifying... Buffer
    Verify Failed, Address=0x000000, Device=0xF9, Buffer=0xA0
    Verify Failed
    Elapsed time: 4.54 seconds.
    Speed = 1
    Oct 2015
    who is chip manufacturer? choised right one? try firichild than your programmer will use low voltage. will know is there problem??????
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    Are you sure that is 93c56 or is 93CS56?
  10. The Following 2 Users Say Thank You to lupu_sandu For This Useful Post:
    smokey08 (7th December, 2016), yugo45 (8th December, 2016)
  11. #10
    daniersms's Avatar
    South Africa
    Ok if you want you can send me the file and I will try with my Willem to write a chip and see if it writes or not
    Love this forum
  12. #11
    klaudio's Avatar
    Jul 2016
    Manufaturer F
    fairchild, that's a whole new game for me, I'm fairly new at this, leave in a small country, no electronic parts supply, , everything i need i have to order from new zealand or u.s., i guess i'm stuck for the time being, does anyone know if x431 will match ecu to immo?
  13. #12
    klaudio's Avatar
    Jul 2016
    ECU liana 93c56.rar
    thanks, by the way it is 93c56
  14. #13
    Above sea-level
    Smd ic? If yes, no short circuit or bad contact in your adapter?
  15. #14
    klaudio's Avatar
    Jul 2016
    Quote Originally Posted by budG60 View Post
    checked several times, disconnected and reconnected, i don't think that's the issue, I can erase, once erased it verifies, after it won't write, did a blank check no results.
  16. #15
    BAILE ATHA CLIATH
    try reload software from mcu mall
