Results 1 to 10 of 10
Hybrid View
    Nov 2016
    Thumbs up dreambox dm 800hd se
    Hi, could someone please help me to solve my problem with dreambox 800hd se no c a found. I suspect it's a clone but not sure and from reading other posts it looks like it may need refreshing with a new image. could someone please talk me through the necessary steps needed to accomplish this, thanks in advance
    digicon's Avatar
    Jul 2009
    Nov 2016
    Thanks digicon. not sure which image I need for my box
    toysoft's Avatar
    Nov 2008
    Use the JapharFlasher, it will restore any DM original or clone, and flash the ALLSIM SSL so you are sure to recover it.
    Here you can download the JapharFlasher from MEGA : https://mega.nz/#!7c4RDSBR!tHuDF-84p...L9uQievaNpLq4U
    Then once you know which sim you have inside, you can flash the proper image,
    You can also read more about it here,
    http://www.digital-kaos.co.uk/forums...on-your-DM-box
    TS
    Nov 2016
    I've had a look at the sim and it's a plain white one and says DM800SE SIM210 C. Do you think that it's a clone and if so the JapharFlasher will be ok? Can I just add that I'm not very good at this kind of thing and hope you can take me through it gently, thanks in advance
    Nov 2016
    toysoft, really appreciate your help. Do I download the JapharFlasher to my pc or is it flashed straight to box?
    toysoft's Avatar
    Nov 2008
    JapharFlasher is a Universal DreamUP, that works with all Original and Clones boxes/Sim,
    TS
    Quote Originally Posted by Ollybee49 View Post
    digicon's Avatar
    Jul 2009
    Your Sim2 uses those Clone images here is the latest OpenATV 5.3 image for your receiver:
    https://mega.nz/#!VgJkHILQ!L71WyS50JsOjgH-Plb89ZGNR-eMrKG6sCL2fFYnuTog?dl=1
    Make sure you have the latest Bootloader installed for your Sim2 for this image to work: http://www.digital-kaos.co.uk/forums...o=file&id=2853
    You flash the bootloader in exactly the same way as you would an image, follow the guide posted
  9. The Following User Says Thank You to digicon For This Useful Post:
    martin035 (8th December, 2016)
  10. #9
    Nov 2016
    Sorry for not getting back sooner but have been busy at work. Thanks, digicon you a star, really appreciate your help. So I install bootloader first and then image? I wiil follow the installion process posted earlier and hopefully understand it. Just one thing could you please tell me which cables I need to connect my dreambox to pc etc
  11. #10
    Nov 2016
    Also just a quickie, my dmbox has a mini flash button on the back of it could you please explain how to reflash using this button or is it the same as the previous post by you on reflashing new image?
