Hi fellows I have a problem with this car
Dtc: DF276
2 AAAAAA injectors and I can not clip with some other method or I must do thanks and regards
Dtc: DF276
have you mpps or fgtech / kess ?
http://www.digital-kaos.co.uk/forums...=1#post2908591
S? tengo fgtech
What am I supposed to do now?
unzip injector scenic 1_fgtech.rar and try write to ecu in injector coding in fgtech menu and then see if you can change if you need too ,. l heard it should be ok ? save your injector file first
let us know if its ok
sorry only edc16 yours is abit old , then
garagesport (11th December, 2016)
My fgtech has no menu of injectors
the ecu :edc15c2
If I'm sorry if I have a menu of injectors I'm going to record file
This car is edc15c2 can not
Any more options for this car
Fgtech only option edc16
clip should work then if edc15 you have the codes right and not mixing 1 or l and so on ?
Thanks solved
Give me your skype to be in touch thanks
what was it then ?
its a forum will help others if you leave feedback
