Results 1 to 9 of 9
Hybrid View
    Oct 2016
    Default Renault laguna 1.9 dci 2005 problem injector df276
    Hi fellows I have a problem with this car
    Dtc: DF276
    2 AAAAAA injectors and I can not clip with some other method or I must do thanks and regards
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    Oct 2016
    S? tengo fgtech
    What am I supposed to do now?
    Mar 2008
    birmingham
    unzip injector scenic 1_fgtech.rar and try write to ecu in injector coding in fgtech menu and then see if you can change if you need too ,. l heard it should be ok ? save your injector file first
    let us know if its ok
    sorry only edc16 yours is abit old , then
  5. The Following User Says Thank You to smirnoff_rules For This Useful Post:
    garagesport (11th December, 2016)
  6. #5
    Oct 2016
    My fgtech has no menu of injectors
    the ecu :edc15c2
    If I'm sorry if I have a menu of injectors I'm going to record file
  7. #6
    Oct 2016
    This car is edc15c2 can not
    Any more options for this car
    Fgtech only option edc16
  8. #7
    Mar 2008
    birmingham
    clip should work then if edc15 you have the codes right and not mixing 1 or l and so on ?
  9. The Following User Says Thank You to smirnoff_rules For This Useful Post:
  10. #8
    Oct 2016
    Thanks solved
    Give me your skype to be in touch thanks
  11. #9
    Mar 2008
    birmingham
    what was it then ?
    its a forum will help others if you leave feedback
