Hello all.When I add smart to CX5 and then the key blinks with the native too,But both smart keys work,What am I doing wrong?Thanks
Mazda cx5 2014.add key used,The key blinks on the dashboard
Best Regards
Taxo
Wrong key........
fiat grande punto 2008
read pin code failed
make dealer key failed
add key ok (make dealer tmpro2)
Lonsdor found 4 pin codes.
The first one was alright. I "programmed" the key.lonsdor saying key learn successfully but car not started and remote didn't worked.
I also tried all the other pin codes.the system did not allowed me to go further because we're wrong.
Programmed with another tool,same key card everything alright
@comizelu what car?
Yes it does this since update, you dont even need to insert the card for it to say programmed, its not even trying to program the key anymore, theyve removed the program step and put it onto the paid function version
Tools owned -
@p1et
Renault Megane 2004
3 buttons key card
Are the cars that are a paid option displayed in the lonsdore menu but you get a warning when you try and select them or are they not displayed at all?
If they are not displayed, how can you know you need to pay for the subscription?
No, I will not download the latest PDF and check if it's in red.
p1et (28th May, 2019)
Lonsdor@ update button does not work good. Need to press hunderd times before it react.
