Has anyone programmed one of these nissan intelligent keys, it is for a 2009 Qashqai,
i have a customer with AKL situation
Tools owned -
Tools owned -
KEY GO (14th June, 2019)
2014 peugeot partner pin ok and add remotekey ok
2007 VW EOS pin failed to read does anyone have any suggestions? Tried dashboard read and ECU and both failed on immobiliser 2&3 even tried immobiliser 3,5 don't know what that one is for otherwise...
Fiat Ducato 2008-2009 id48 akl -ok
A few times failed with pin and programming but insisted and worked.
Peugeot partner 2012 akl read pin under type2 and program ok
Renault Laguna III 2009 AKL Failed on add key/card
Alfa 147 2006 add remote failed (no comunication)
PocketHero (18th June, 2019)
Citroen Jumper 2013 did under Fiat Ducato 2012+
Read pincode OK, prepare dealer OK, learn OK - buttons work.
My trial expired, so I have no Jumper under Citroen.
If I helped you know what to do..
Brof (18th June, 2019), PocketHero (19th June, 2019)
Audi A1 2012 akl fail
Ecuprog31 (18th June, 2019)
Hi, this device work VOLVO S40 2004-2008 ID48 all key lost? remote function work?
