Page 127 of 225 FirstFirst ... 2777117122123124125126127128129130131132137177 ... LastLast
Results 1,891 to 1,905 of 3369
Thread: LONSDOR K518
  1. #1891
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by kluczbum View Post
    try to repair using Renault
    CAN / K-line ECU Tool
    the best tool for renault
    With ECU tool not possible make any diagnosis. I bought second hand HFM same part numbers, renewed and adapted with ECU Tool it but there's same situation like after dealer reprogrammed existing one. Noone can explain what is going on and where is the problem.
    In Captur it's more difficult to remove HFM than Clio (in Clio it's piece of cake) so I decided to risk and give it a try without removing HFM and reading D-Flash. I never thought it might be so fckn problem to fix it afterwards if it gone bad... I had in mind if something will mess up then no big problem, buy used HFM, renew it (if they could not reprogram that one with data loss) and go to dealer for programming. But it's just a nightmare right now.
  2. #1892
    Apr 2016
    [QUOTE=p1et;3650320]With ECU tool not possible make any diagnosis. I bought second hand HFM same part numbers, renewed and adapted with ECU Tool it but there's same situation like after dealer reprogrammed existing one. Noone can explain what is going on and where is the problem.
    maybe lonsdor broke something else
    I would be looking for new modules from another carScreenshot_20190818-202537.jpg
  3. #1893
    p1et's Avatar
    Oct 2013
    Yeah it seems it broke something else but dealer have no clue as no any errors in diagnose. Complete starter kit is last option which I consider, tomorrow car going to electronic technician who think can solve it but honestly i'll be very surprised. And I bet even if I buy starter kit there will still be a problem bcoz it's fckn RENAULT
  4. The Following User Says Thank You to p1et For This Useful Post:
    kluczbum (18th August, 2019)
  5. #1894
    Apr 2016
    how did the car die?
    the card opens the car?
    steering lock unlocks?
    not responding to the start?
    is nothing working?
    hey people, let's think how to help a friend!
  6. #1895
    p1et's Avatar
    Oct 2013
    Lonsdor erased D-Flash (not whole but most of, however VIN was still visible in corrupted file) from HFM (P-Flash looked OK) and there was no ignition, no central locking from card, on dash 'please control steering lock'. Dealer reprogrammed HFM and central locking on card is working now (both open/lock functions) but ignition still won't come up however ELV opens after card is put into the reader.
    Honestly noone knows what to do, noone met with such symptoms before. I suspect maybe dealer did something wrong but I don't know what to really think. But ECU Tool after identification show it's version without keyless but car is with keyless and everything was working before.
    I will update about this case if anything change.
  7. The Following User Says Thank You to p1et For This Useful Post:
    jodge (18th August, 2019)
  8. #1896
    super jumbe's Avatar
    Livingstone
    Quote Originally Posted by p1et View Post
    Lonsdor erased D-Flash from HFM (P-Flash looked OK) and there was no ignition, no central locking from card, on dash 'please control steering lock'. Dealer reprogrammed HFM and central locking on card is working now (both open/lock functions) but ignition still won't come up however ELV opens after card is put into the reader.
    I can see you going through hell mate wish you all the luck.
  9. The Following User Says Thank You to super jumbe For This Useful Post:
    p1et (18th August, 2019)
  10. #1897
    Sep 2018
    Its becouse Lonsdor doing "copy" "paste" of modulation from other tools and dont even test it. We are all beta testers. And stuffs like that p1et will happen again soon or later.
  11. #1898
    jmautoman's Avatar
    Jun 2019
    Dacia Duster 2017.. Read Pin OK!!!!!!! Add Remote Key OK!!!!!!!
  12. The Following 3 Users Say Thank You to jmautoman For This Useful Post:
    holbi1 (19th August, 2019), p1et (19th August, 2019), PocketHero (23rd August, 2019)
  13. #1899
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by jmautoman View Post
    Nice... How long it took?
  14. The Following User Says Thank You to p1et For This Useful Post:
    RIMKACHIP (20th August, 2019)
  15. #1900
    jmautoman's Avatar
    Jun 2019
    After reading your post about the #####Captur#### I was a bit worried.. All together less than five min...
  16. The Following User Says Thank You to jmautoman For This Useful Post:
  17. #1901
    Dec 2016
    .... Dealer reprogrammed HFM and central locking on card is working now (both open/lock functions) but ignition still won't come up however ELV opens after card is put into the reader.
    There is an configuration problem , your car is OK
    Use Renolink £30 to change it
  18. #1902
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by TERMINATOR1000 View Post
    Yeah I read about that yesterday that it's possible to change. At first I thought they just programmed wrong SW in HFM but now I have hope it will work after change that configuration. CAN Clip I guess will also be OK for that?
  19. #1903
    Dec 2016
    If key open the car and start too , if tool detect no hands free car : HFM is no HF car
    Hope is just an configuration , i don't use CAN CLIP ...
  20. #1904
    p1et's Avatar
    Oct 2013
    But the thing is car DON'T start, even ignition doesn't turn ON. Only ELV unlock after card put into reader and card lock/unlock car from buttons.
    If this was just about HF I would be in heaven.
  21. #1905
    rola1971's Avatar
    Jun 2014
    Dublin
    fiat 500 2018 add remonte key. read pin ok add key ok
  22. The Following 2 Users Say Thank You to rola1971 For This Useful Post:
    jmautoman (20th August, 2019), p1et (20th August, 2019)
