Ecuprog31 (12th January, 2020), p1et (13th January, 2020), PocketHero (13th January, 2020), vialli (13th January, 2020)
Ford Transit 2008 add remote key OK
Honda Civic 2009 AKL add remote key OK
Lads good news coming soon.......
Staafonline (3rd February, 2020)
does lonsdor let you reset km in Bmw Fem/bdc?
many thanks
Stop getting worried about what could go wrong, and start getting excited about would could go right!
hmmmmmmm........eeprom
Digi v4.94, Xtool, R260, R270, Smok, VagProg DataSmart 3+ Smelecom, Autel Maxisys ms908, SpeedFilters
Is the Megane 4 akl all by obd
On this tool or you need to read
The hands free module separately.
godfathertre (20th January, 2020)
godfathertre (19th January, 2020)
2013 Volvo V60
Read security data fails.
Even when the contact points were soldered together just to avoid bad contact.
Can somebody explain price of this tool and upgrades on this Londsor.
fiat Talento 2017 (Renault Trafic 3) pin read add key failed
Renault Trafic 3 2015 pin read add key ok
Citroen Berlingo 2016 pin read add key ok (under peugeot expert)
Opel Movano 2016 add key ok (under renault master 2010-2015)
i will keep testing trafic till it works one day but so far no luck on any Trafic 3 after 2015
But you just said you've done one? And if I remember correctly, you did one in the past as well.
BTW. If we do Trafic / Vivaro 2015+ spare key and the same car will loose all keys someday, will be possible to program key then? Because when you add key, need to update FLASH to unlock BCM so if done once I guess AKL possible but I dont know? Just out of curiosity...
So is this tool safe on latest Renault or hit and miss and you might need a good insurance if something goes wrong.
Opel/vauxhall astra H 2008, what is success rate of lonsdor reading pin?
