Page 147 of 225 FirstFirst ... 4797137142143144145146147148149150151152157197 ... LastLast
Results 2,191 to 2,205 of 3369
Thread: LONSDOR K518
  1. #2191
    Jun 2019
    Quote Originally Posted by p1et View Post
    But you just said you've done one? And if I remember correctly, you did one in the past as well.
    BTW. If we do Trafic / Vivaro 2015+ spare key and the same car will loose all keys someday, will be possible to program key then? Because when you add key, need to update FLASH to unlock BCM so if done once I guess AKL possible but I dont know? Just out of curiosity...
    Yes after 2015 that means 2016 and younger.
    If you try it wont allow you to read or write flash it just flashes lights once and the it says read pincode failed.
  2. #2192
    p1et's Avatar
    Oct 2013
    Yes but Trafic 3 is from 2015 and you did one (2015). Someone else did 2017 so that means software is still not developed or to be more accurate - copied very well... I was just confused because you said did Trafic 3 and then said no luck on any Trafic after 2015 when it' same car but now I understand you succeed in 2015 Trafic 3 but not on 2016 and younger
  3. #2193
    jmautoman's Avatar
    Jun 2019
    I have done Trafic 3 2017 under system 1 read pin (32 digits)and add key ALL Good..... But I tryed fiat talento and tryed to read the pin awnser was ----NO COMIUNICATION--- p1et--- like you seid Renault works 50>50 ...
  4. The Following User Says Thank You to jmautoman For This Useful Post:
    RIMKACHIP (21st January, 2020)
  5. #2194
    Feb 2015
    Lincolnshire
    2012 vw caddy add new key works well. Read immo data for backup, add key, job done obd.
    Stop getting worried about what could go wrong, and start getting excited about would could go right!
    hmmmmmmm........eeprom
    Digi v4.94, Xtool, R260, R270, Smok, VagProg DataSmart 3+ Smelecom, Autel Maxisys ms908, SpeedFilters
  6. The Following User Says Thank You to Dayo For This Useful Post:
  7. #2195
    vialli's Avatar
    Aug 2018
    Romania
    BMW X1(E84), 2011 cas3+, add new remote key OK
    BMW 3 series(E92), 2008 cas3+, add new remote key OK(after programming shows steering lock---click "sync ELV" and solved)
    Skoda Superb 2010, all keys lost, read immo data with Vag Obd helper, make dealer key and program one key with Lonsdor OK
  8. The Following 2 Users Say Thank You to vialli For This Useful Post:
    jmautoman (21st January, 2020), p1et (21st January, 2020)
  9. #2196
    Feb 2015
    Lincolnshire
    Quote Originally Posted by vialli View Post
    lonsdor not read immo data for skoda obd?
  10. #2197
    vialli's Avatar
    Aug 2018
    Romania
    Can't read immo data when all keys lost, if you have a valid key is able to read immo
  11. #2198
    Feb 2015
    Lincolnshire
    can you message me link to vag obd helper? What is price?
  12. #2199
    Sep 2013
    Anybody try Alfa 159 with slot key?
  13. #2200
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by holbi1 View Post
    Didn't try by myself but I saw reports by users who's done with success.
  14. The Following User Says Thank You to p1et For This Useful Post:
    holbi1 (21st January, 2020)
  15. #2201
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    Yes, I did. It won't work good. Better you make a simple key without remote, and put it into the emergency hole. The car Will start.
    This machine is unable to make key precoding correctly, the remote won't work.
    Tried with factory keys reopened, with or without changing eeprom chip.
    But if you put the correct precoding to the key with other machine, it teaches it fine and the remote Will work too
  16. The Following User Says Thank You to PocketHero For This Useful Post:
    Weasel3 (22nd January, 2020)
  17. #2202
    p1et's Avatar
    Oct 2013
    I saw report by person who did 2 times full remote key all by K518 and all worked, remote also. Only problem was to place properly new key in K518 slot for precoding but I guess it's better put only PCB without shell for precoding and this problem should be gone.
    Maybe it depend which tool you use to unlock original second hand remotes as some might have done it wrong. I just reminded myself that my friend had such problem with AVDI. Apparently there are 2 versions of that key and need other renew files, something like that... But I know he programmed key and remote also didnt work, so changed key and worked
  18. #2203
    PocketHero's Avatar
    Jun 2017
    Budapest, Hungary
    All what you wrote is correct, there gives 2 kind of keys. The choice depends on the data, what you can find in BSI. However, it toke 2 days tó make a perfectly working key to the car.
    Unlocking was made with X2, coz I knew the AVDI failure. The @ the end working key too.
    Precoding was made Always with the whole key, not just the pcb. That could be a problem.
    As everybody knows, Tango is unable to make the precoding correctly, was used to make a 7936. At the end that chip was precoded a teached by Lonsdor to b able 2 start the car.
  19. The Following 2 Users Say Thank You to PocketHero For This Useful Post:
    p1et (22nd January, 2020), Weasel3 (1st February, 2020)
  20. #2204
    is there a site or other way to check by when do I have important updates purchased in my lonsdor?
  21. #2205
    vialli's Avatar
    Aug 2018
    Romania
    Quote Originally Posted by artfull View Post
    Open your device, click on "one key update" next click on"Log update" and you can see all update history
