Page 202 of 225 FirstFirst ... 102152192197198199200201202203204205206207212 ... LastLast
Results 3,016 to 3,030 of 3369
Thread: LONSDOR K518
  1. #3016
    jmautoman's Avatar
    Jun 2019
    Quote Originally Posted by p1et View Post
    You sure you have correct key? There are 2 types (keyless / non keyless)
    Yes the key is non keyless and same with the car....
    Wysłane z mojego Redmi Note 9 Pro przy użyciu Tapatalka
  2. #3017
    vialli's Avatar
    Aug 2018
    Romania
    Skoda Octavia 2008, CDC+24c32 add spare key successfully
  3. The Following 2 Users Say Thank You to vialli For This Useful Post:
    mexanico1971 (14th April, 2021), p1et (6th April, 2021)
  4. #3018
    Sep 2010
    CLIO 2006 ADD SPARE KEY SUCESS
  5. The Following User Says Thank You to triak88 For This Useful Post:
  6. #3019
    2010 porsche cayenne, non keyless-go, add key fail.
    displayed "Immobiliser activated" on the cluster and car shut down.
    Luckily I had read out kessy 93c86 beforehand, restored original data, and car woke up.
    someone said on this forum that "leave ign on and wait 5minutes".
    not work.
  7. The Following User Says Thank You to nyandacca For This Useful Post:
    habbyb (10th May, 2021)
  8. #3020
    Hungary, Mosonmagyar?v
    2013 Toyota Verso add smartkey OK . 2 minute job .
  9. The Following User Says Thank You to kareszka For This Useful Post:
  10. #3021
    Ecuprog31's Avatar
    Mar 2018
    Master 2 add key start one time but immo led blinking
    then it can’t start
    finish job with RET
  11. #3022
    darrenhyland's Avatar
    Aug 2010
    IRELAND
    Quote Originally Posted by Ecuprog31 View Post
    then it can’t start
    finish job with RET
    I find Master programming needs doing twice sometimes but always works......I usually remove key after programming and wait until led starts blinking before trying.
    Tools owned..... Kess3 Master, Bitbox, TGFlash, VVDI2 Full, VVDI Prog, VVDI MB Tool, VVDI Mini Tool, VVDI Key Tool Max Pro, VCX series for BMW Ford Mazda Jaguar Land rover VAG Toyota Volvo GM, PCM Flash + Scanmatik2, Lonsdor K518ise, Magic tank and every other piece of Chinese crap out there.
  12. The Following User Says Thank You to darrenhyland For This Useful Post:
    p1et (13th April, 2021)
  13. #3023
    newone's Avatar
    Oct 2016
    megane iv,espace v add ok,5 minutes job
  14. The Following 2 Users Say Thank You to newone For This Useful Post:
    mexanico1971 (14th April, 2021), p1et (13th April, 2021)
  15. #3024
    ghostrider72's Avatar
    Jul 2012
    UK
    So... who’s gonna be the first one to test it?
  16. The Following User Says Thank You to ghostrider72 For This Useful Post:
    Weasel3 (13th April, 2021)
  17. #3025
    Ecuprog31's Avatar
    Mar 2018
    Quote Originally Posted by darrenhyland View Post
    But it’s strange immo led blinking and van start ...second try nothing
  18. #3026
    Aug 2010
    IRELAND
    Yes that is normal.......immo is still in programming mode.....programe then remove key until led starts blinking before trying to start.
  19. #3027
    Nov 2018
    Quote Originally Posted by ghostrider72 View Post
    Did they rip it off?
    Sent from my SM-N960U using Tapatalk
  20. #3028
    Did they also copy this 😆
  21. #3029
    didi_du_93000's Avatar
    France Paris
    Anyone have try akl on trafic 3, twingo 3, smart 453...?
    Envoyé de mon LYA-L29 en utilisant Tapatalk
  22. #3030
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by didi_du_93000 View Post
    No chance. Only add key possible and not always work.
  23. The Following 2 Users Say Thank You to p1et For This Useful Post:
    didi_du_93000 (22nd April, 2021), Ecuprog31 (15th April, 2021)
