Anyone make ecosport 2018 us market ?
Wysłane z mojego SM-G920F przy użyciu Tapatalka
mexanico1971 (3rd February, 2021), p1et (28th January, 2021), RIMKACHIP (29th January, 2021), Weasel3 (28th January, 2021)
Chrysler 300C 2014 USA keylles read pin ok add prox ok
mexanico1971 (3rd February, 2021), p1et (29th January, 2021), RIMKACHIP (29th January, 2021)
Audi A6 C7 2017 USA add key - Lonsdor or VVDI2 can handle BCM, will I have to use Vag obd helper?
Ecuprog31 (30th January, 2021), mexanico1971 (3rd February, 2021), p1et (30th January, 2021), TERMINATOR1000 (30th January, 2021)
Anyone tried Renault Kadjar recently? Until now, it seems every person who tried actually failed in key programming to this particular one.
Hello
- 2006 Fiat grande Punto ( Black BSI ) fail to read PIN code , finish job with ; I.O TERMINAL + VVDI key tool + MultiEcuScan + time lose ....
- 2010 OPEL Insigna , read PIN code in 30 seconde , errasse fault code OK , ADD key OK after 8 minutes
mexanico1971 (6th February, 2021)
opel corsaE,read pin ok add key ok,add key option worked with new key from the beggining of proccedure
Hello
yes , just need more 10 minutes & no mistake , I.O PROVIDE me the 6 pages of transponder pré-code + PIN code , i write it manually using my keytool .
you can use AVDI ProTAG + EEPROM data read by I.O
I finish job by Fiat diagnostic MultiEcuScan with PIN code
honda1200 (9th February, 2021)
Does it support i30 2016-2021, AKL? Anyone knows?
Fiat 500 2019, anyone tried? From which production year the BSI is locked?
