Page 184 of 225 FirstFirst ... 84134174179180181182183184185186187188189194 ... LastLast
Results 2,746 to 2,760 of 3369
Thread: LONSDOR K518
  1. #2746
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by auto techniek View Post
    Peugeot 206 from 2010 failed to read pin.
    You sure 206 model?
  2. #2747
    auto techniek's Avatar
    Mar 2017
    Yes. I was amazed
  3. #2748
    Ecuprog31's Avatar
    Mar 2018
    Quote Originally Posted by p1et View Post
    You sure 206 model?
    2010 it’s 206+
  4. #2749
    Ecuprog31's Avatar
    Mar 2018
    Hyundai getz 2005 id46
    read pin fail
    vin to pin ok
    learn key ok
  5. The Following User Says Thank You to Ecuprog31 For This Useful Post:
    RIMKACHIP (23rd September, 2020)
  6. #2750
    Sep 2016
    Quote Originally Posted by didi_du_93000 View Post
    Fiat 500x 2018
    AKL
    Can't connect to read pin
    With Tapatalk
    Did you use sgw bypass?
  7. #2751
    didi_du_93000's Avatar
    Dec 2009
    France Paris
    Quote Originally Posted by qeso705 View Post
    Yes
    With Tapatalk
  8. #2752
    Apr 2017
    HELLO, my lonsdor can no longer connect to PSA peugeot citroen vehicles,
    I can read the pin code but when programming the keys, no connection, is it an update problem or a hardware problem?
    regards
  9. #2753
    Mar 2020
    you can try to read the pin through citroen. Sometimes it works.
  10. #2754
    p1et's Avatar
    Oct 2013
    Yes. I was amazed
    Did you try Type 4?
  11. #2755
    Dec 2009
    France Paris
    fiat 500X 2018 AKL
    DONE!!!
    first test fail due to broken bypass SGW.
    I have use smart key from Xhorse, but keyless don't work. work only when i put key in Start/stop button (antenna).
  12. The Following User Says Thank You to didi_du_93000 For This Useful Post:
    p1et (27th September, 2020)
  13. #2756
    Dec 2009
    France Paris
    Toyota verso 2010AKL
    DONE!!!
    reset immo, program immo + add 2 master key + 1 valey key.
  14. The Following User Says Thank You to didi_du_93000 For This Useful Post:
  15. #2757
    Aug 2013
    Macedonia
    Ford Fusion 2008 after low battery key was erased
    Lonsdor count 0 keys to add key connection Fail
    with vcm reset modul add 2 keys all ok
    maybe lonsdor can not access to dash because coruption is made
  16. #2758
    Mar 2017
    France
    Add card scenic III year 2015 ok
    Envoyé de mon POT-LX1 en utilisant Tapatalk
  17. #2759
    ASCM's Avatar
    Oct 2018
    Quote Originally Posted by omarino View Post
    Where did you bought your card its unlocked one or its new one from china
    Sent from my SM-J415F using Tapatalk
  18. #2760
    Mar 2017
    France
    Quote Originally Posted by ASCM View Post
    This New one from China
