Page 88 of 225 FirstFirst ... 3878838485868788899091929398138188 ... LastLast
Results 1,306 to 1,320 of 3369
Thread: LONSDOR K518
  1. #1306
    Jan 2017
    USA ����
    Quote Originally Posted by alex_r_2001 View Post
    Also did not work for 2014 Dodge Ram 1500
    which type of ignition?
    y170 pod?
    blade?
    fobik?
    keyless go?
    prox?
    fail on pin?
    no connection at all?
    you have right key? fobik is GQ4-53T for ram
    The thanks button is HERE looks like this --->>> THANKS
  2. #1307
    Jun 2018
    England
    Default LONSDOR K518
    Double post
    If i helped please press the thanks button
  3. #1308
    Jun 2018
    England
    2015 Hyundai Tucson not work at all to program new key.. Only tool that worked for me was Autel Ms908..
    https://www.digital-kaos.co.uk/forums/showthread.php/563630-LONSDOR-K518?p=3444187&viewfull=1#post3444187
    Read my post, Tucson does work but not by selecting it on the menu
    Sent from my Pixel 2 XL using Tapatalk
  4. The Following User Says Thank You to paulsta For This Useful Post:
    PocketHero (6th February, 2019)
  5. #1309
    Jun 2018
    England
    Ford KA 2009 AKL
    Used Fiat 500 to do the job
    Read Pin = Pass
    Program Key = Pass
    Remote Precode = Fail (i selected 8 pins and key was 10)
    Peugeot 206 2004 AKL
    Read Pin = Pass (Type 4 K-Line)
    Program Key = Pass
  6. The Following 6 Users Say Thank You to paulsta For This Useful Post:
    anton316 (7th February, 2019), HeXeN (7th February, 2019), kostat (5th February, 2019), lalaina74 (5th February, 2019), PocketHero (6th February, 2019), rola1971 (5th February, 2019)
  7. #1310
    Jan 2017
    USA ����
    Quote Originally Posted by paulsta View Post
    not sure why but that linky no worky
    also hes in the USA its possible its a different system??
  8. #1311
    Jun 2018
    England
    Quote Originally Posted by sleepyrz View Post
    I had same issue selecting Tucson, It just kept failing so i used Santa FE and it worked
    not sure about the link though as it shows the correct post number
  9. #1312
    Jun 2018
    England
  10. #1313
    Jul 2018
    Polska
    Mazda CX-5 2017 USA
    Add key - OK
    Time - 7min
    Jeep Grand Cherokee 2014 USA
    Add key - OK
    Time - 3min
  11. The Following 5 Users Say Thank You to mobilek For This Useful Post:
    habbyb (15th February, 2019), kostat (13th February, 2019), PocketHero (12th February, 2019), RIMKACHIP (16th February, 2019), taxo1965 (13th February, 2019)
  12. #1314
    Jun 2018
    England
    2013 Corsa D (This is a paid function)
    Pulled wrong pin
    Used another tool to get correct pin
  13. The Following 2 Users Say Thank You to paulsta For This Useful Post:
    p1et (16th February, 2019), RIMKACHIP (16th February, 2019)
  14. #1315
    p1et's Avatar
    Oct 2013
    Pulled wrong pin
    On monday I will have Corsa D same year (2013). We'll see the results - I will report here
  15. #1316
    autochei's Avatar
    Mar 2013
    romania
    pass--- succes or fail?
  16. #1317
    Jun 2018
    England
    Quote Originally Posted by autochei View Post
  17. #1318
    p1et's Avatar
    Oct 2013
    Corsa D 2013 - read pin - OK, program key FAIL (under menu of Corsa D it displayed 'wrong pin code' - I did not try other menus for programming). The PIN code read by Lonsdor was OK because I programmed this car with AD100 pro using same code.
    Iveco Daily 2008 program remote FAIL (no comms with car), done with MVP
    VW Sharan 2012 FAIL to backup immo data (before trial version I made a couple and worked fine), done with other tool
  18. The Following 5 Users Say Thank You to p1et For This Useful Post:
    Ecuprog31 (19th February, 2019), kostat (20th February, 2019), newone (19th February, 2019), paulsta (19th February, 2019), PocketHero (20th February, 2019)
  19. #1319
    Jun 2018
    England
    Quote Originally Posted by p1et View Post
    It still doesn't justify $600 for the paid subscription, they need to come with something better than this as other tools do the job token free.
  20. #1320
    Jun 2017
    Europe:
    OPEL CORSA C: Pin OK under type3 (fail under corca c menu), add key OK, remote fail (done with zed-full)
    HONDA H-RV 2015 immo+remote OK (IMMO TYPE 2)
    OPEL ASTRA H: Pin OK (type3), add key+remote OK.
    Strange thing, corca c with id40 and astra h with id46, worked under the same option, type 3.
  21. The Following 4 Users Say Thank You to kostat For This Useful Post:
    Ecuprog31 (19th February, 2019), p1et (19th February, 2019), PocketHero (20th February, 2019), RIMKACHIP (21st February, 2019)
