Results 1 to 10 of 10
    WALES
    Default MPPS 13.02 problem
    Hi, I just installed a tool with 13.02 and after installing software I get this message
    any ideas????
    wbr
    Dec 2016
    Europe
    Driver must be installed and cable plugged to computer
    WALES
    Quote Originally Posted by marprog View Post
    It is, and driver is correctly installed
    wbr
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Push button start and it is load if I good remember ?
    Scripts for Multi-PROG
    Best regards.
    Dragon
    WALES
    Quote Originally Posted by dragon100 View Post
    Please read whole thread, there is NO start button because the software doesn't start
    Jan 2014
    Ro
    Run as administrator
    Trimis de pe al meu SM-G900F
  7. The Following User Says Thank You to tarabostesul For This Useful Post:
    shooting (15th December, 2016)
    WALES
    Quote Originally Posted by tarabostesul View Post
    PERFECT!!!! Works
    Thank you sooooo much...
    wbr
    dragon100's Avatar
    Jan 2012
    Be careful when you write flash with ME7.5 ME7.1 and EDC16.
    Best regards.
    Dragon
  10. #9
    Indeed, ME7.5 with 29F400 don?t work... it start asking for cicle ignition and no go... Have to recover with old 1260
    Those with 29F800 and tiptronic didn?t work either
  11. #10
    WALES
    New Problem,
    I'm using this MPPS to read a Laguna1 Phase2 ECU "Sirius32", there is no option for this in MPPS software,
    can I use Twingo "Sirius32" setting to read this ECU or is there a known problem?
    wbr
