Results 1 to 4 of 4
    May 2012
    Default BMW E46 2.0 150cv 1037361858 DTC delete
    Hi, I have a problem with this BMW. Is the file original? I am comparing it with files downloaded from the internet and they are not the same. On the other hand, I need to eliminate the following Airbag faults. It's possible? ThanksIMG_1594.JPG
    doctore's Avatar
    Nov 2015
    Colorado Denver
    resistors 2 100 ohms connect to airbeg and no errors more
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  3. The Following User Says Thank You to doctore For This Useful Post:
    Car28th (22nd December, 2016)
    May 2012
    You mean put the resistors in the module under the passenger seat? Is it possible to delete errors in the file? Thanks
    doctore's Avatar
    Nov 2015
    Colorado Denver
    i mean if your airbeg fired then you this is the easiest solution to do that, if not wait to someone clear errors in fail if is possible
