Page 1 of 2 12 LastLast
Results 1 to 15 of 19
    koziolek's Avatar
    Feb 2010
    Under the car
    Default Key Cutting Copy Machine 368A question
    Does someone have any experience with that tool?
    is it worth to pay $130 ?
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Quote Originally Posted by koziolek View Post
    works like a rocket with titanium drill
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  3. The Following User Says Thank You to doctore For This Useful Post:
    koziolek (24th December, 2016)
    Apr 2010
    I stop using it after 2 keys, junk in my point of viwe beacuse it jump and bump all over the key , but maybe if i was using proper cutter its will be better, never tried, got silca matrix for few years and its never let me down.
  5. The Following User Says Thank You to totalkey For This Useful Post:
  6. #4
    camelgd's Avatar
    Jan 2011
    South Illinois
    I have one, no problems as long as you use good quality cutter,NOT the ones that come with it. I use hss instead of carbide with it, seems to work better. As an aside, I am trying to attach space and depth micrometers to it to cut keys by dimension without depth keys. Not a priority, but would be nice to be able to do that.
  7. The Following 3 Users Say Thank You to camelgd For This Useful Post:
    doctore (23rd December, 2016), koziolek (24th December, 2016), totalkey (23rd December, 2016)
  8. #5
    super jumbe's Avatar
    Dec 2008
    Livingstone
    If you are going to do for business the ?130 I will not recommend, depends how much you want to spend but for just under ?960 I would go for MIRACLE-A7 Key Cutting Machine look at the photo.
  9. The Following 2 Users Say Thank You to super jumbe For This Useful Post:
    doctore (24th December, 2016), koziolek (24th December, 2016)
  10. #6
    Apr 2016
    uk
    Quote Originally Posted by super jumbe View Post
    Where can I buy this machine?
    Inviato dal mio HTC One utilizzando Tapatalk
  11. #7
    kevfield's Avatar
    Aug 2009
    uk
    Quote Originally Posted by comizelu View Post
    I have this cutter its not very good at all i would save more and buy a condor ! dont get me wrong A7 works but its not the best , or may be try find a used genuine A5 there very good but very slow ..
    Thanks Kev
  12. The Following 2 Users Say Thank You to kevfield For This Useful Post:
    koziolek (24th December, 2016), totalkey (24th December, 2016)
  13. #8
    koziolek's Avatar
    Feb 2010
    Under the car
    so MIRACLE-A7 Key Cutting Machine will not work properly ?
    waste of money?
    CONDOR XC-MINI Master for $3000 will be the best option?
    its like 3 times more expensive
  14. #9
    Dec 2008
    Livingstone
    Just google there are more then 100s company saleying out there, Miracle 7 is a good auto cutter and all cuttings done in auto, if you want the one without any hassle they can cost you over ?20,000...
  15. The Following 4 Users Say Thank You to super jumbe For This Useful Post:
    doctore (24th December, 2016), koziolek (24th December, 2016), rokibar (24th December, 2016), stickmuon (31st December, 2016)
  16. #10
    Apr 2016
    uk
    At the moment I have the 368a.I've done lots of keys with it.bought the carbide cutters and needed 3 of them for cutting a key.not good at all.
    But with titanium cutter is good.I am using it for mobile cutting only.
    Worth all the money.
  17. The Following 2 Users Say Thank You to comizelu For This Useful Post:
  18. #11
    Jan 2010
    waste of money?
    Its not a miracle a7 its a knock off miracle a7.
  19. The Following User Says Thank You to paul_12345 For This Useful Post:
  20. #12
    Apr 2016
    uk
    Quote Originally Posted by paul_12345 View Post
    What about condor xc mini?
    Is ok as an automatic key cutting machine+
  21. The Following User Says Thank You to comizelu For This Useful Post:
  22. #13
    koziolek's Avatar
    Feb 2010
    Under the car
    @ Mr. comizelu can you tell where you buy your titanium cutter please ?
  23. #14
    Apr 2016
    uk
    From Ali..
    5 cutters - ?5
  24. The Following User Says Thank You to comizelu For This Useful Post:
  25. #15
    koziolek's Avatar
    Feb 2010
    Under the car
    just any seller ?
