Please help for DPF off Berlingo 1.6Hdi EDC17C10 0281019817
Code Fault
P1435 Additive pump Fault CAN
P1434 Additive pump
P2297 Lambda Fault
Flash 0281019817 Berlingo EDC17_IntFl TC1797.rar
Code Fault
P1434 Additive pump
P2297 Lambda Fault
you only need lexia for that, restore the additive pump and this found good
I think it is best to eliminate the problem forever. Can you do file?
Here
--> Attachment 417479
Now, The car has no power and causes Fault
U2000 Chain cinematic Bus
Wake up signal.
Any idea?
I have the same problem with a Berlingo 2014 1.6HDI. Made a FAP OFF file and reset the FAP filter. Even programmed the BSI module without additive and FAP and still Limp mode. Any suggestions?
DPF/FAP, AdBlue SCR, EGR, Flaps, DTCs, Lambda, IMMO off, Custom REMAP
*IPTV Provider
No need program bsi or disconnect nothing, there is solution for this via flash only, when P1434 come, need to remove 3 area not just dtc, and delete from ecu anther area for the addtive system,
CVN FIX Vag/Bmw
Tuning Petrol and Diesel
High Power Maps
Custom Tuning Stage 3+ Hybrid
Dsg Tuning
And where are these areas?
*IPTV Provider
you need to find out by your self, as i did for 3 days of work.
CVN FIX Vag/Bmw
High Power Maps
Dsg Tuning
Ah ok. Found it with the help of EDC17C10 Damos. ECU not searching for Additive Pump anymore and no limp.
*IPTV Provider
very good you pro
CVN FIX Vag/Bmw
High Power Maps
Dsg Tuning
