listening to customer is the first problem , there liars , something strange must of happened to go to 80kmh
Hello guys,
I have problem with one Touareg, here is what happened in short lines
Car was ok and runing 240kmh top (said by owner)
He decided that want to crush catalysators and DPFs
And he went to some other shop to do that job.
After that car wouldnt pass 80 kmh
Now he drove car to me , these thing i have done
1st found original software by hardware number
2nd turned off DPF and EGR in that file
3rd all 10 injectors changed
4th both turbos and MAF-s checked on vcds and works perfect in drive
Car now run ok more or less, but cant go pass 190 kmh.
I tryed with both 372955 383058 version of software and car runs same.
anyone have clue what i am doing wrong or someone had same problem ???
Regards Sasha
baltazar3 (23rd December, 2016), mislav88 (24th December, 2016), pulsar2000 (24th December, 2016), smokey08 (23rd December, 2016), toms4 (28th December, 2016)
That is not flash problem, original speedlimit in flash is 300Km/h if i am not wrong. And seeing that car specs, max speed is 225Km/h according manufacturer.
'" live and learn........ if you wont ....you ain't "
_______ . ____ . __ . __ . _______ . __ __ __ ... ---
If my post was HELPFUL please push THANKS button
Someone have MPC file from processor ? I think that might be a problem
so it is edc16u31, u1 pre facelift are without dpf. i have full bdm from both master and slave, i can send it to you on touesday.
and yes, many customers are a big liars, but you always know it at the end of the job. i just play it their way and charge double, you anyway need to spend more time than if they told you the whole story as is
on another forum he says he has found out this indeed was never fitted with dpf's as its early 2005
both sw versions he mentions are from edc16u31, and they have dpf (from 2007). earlier ones with edc16u1 are without dpf (2002-07). both 230kw
yea lm not sure whats going on now
Sasanis Online
Reading Thread I need VW Touareg 5.0Tdi 313PS 070906016DH 0281013305
Given 5 thank(s) in 4 post(s)
RE: Touareg V10 5.0 TDI
Update
- I have read this car dont have DPF at all, its 2005 version
- I have log torque and iq on both sides. Torque looks ok and iq is max 53 mg/stroke
is that too low for this car ???
And car is pulling really good till 3000 rpm, then accelerates way slower !
- Again checked turbos and MAF-s working great
doctore (24th December, 2016)
Sorry dind't updated here. I founded that car dont have dpf at all.
I loged the car and at 190kmh it has 70mg/ stroke, 2550 mbar boost and 1100mg of air in MAF and still cant go over 190 kmh.
I think that ecu, or ecus are broken because i see that they have been opened before.
Anyway i told owner to replace ecus and gave back car to him.
Thanks everybody for trying to help.
