i think start check if you have 2000e for fix problem in very bad situacion
Please help. EDC17CP14 dead after flash galleto. ECU is antitunning.
ThanksGOLF 6 edc17 bricked ECU.zip
so you cant write these in boot mode then ?
o l see you write in obd first .. brave man
you must be able to write ori if someone has it ,, post all hw and sw numbers
cant you write ori back with ktag and patch it so you can obd it next time
try to review the boot line, this ecu is antituning, but the tricore are booted no have problem
mario313 (24th December, 2016)
All thank you very much for the advice. the problem is already solved. He helped me from the forum user cawadany mhhauto.com. I wish you a merry Christmas.
Hy guys,same Problem by me, golf 6 2.0tdi cbdb bricked ecu, I have opened ecu all good , make backup read with kess , read flash , tune it stage 1 , try to whrite flash back all work till 60 % there stop whriting , ecu bricked , now with kess I have tryed recovery and kess 5.017 Euro clone make no id and no recovery, it pop up Micro wake up!!
Tri to read with ktag 7.020 China , sometimes I have id , sw but Ktag stop reading after 2 sectors and pop up a communication error, is there anyway to bring this ecu back to live! Thenks in advance I am located in Germany Wetzlar
Trimis de pe al meu SM-G930F folosind Tapatalk
Your ktag not good, otherwise read and write without problems.
need to fix eeprom and ırom and write boot mode after will be ok
write to me in skype I help you, you no need open ecu and read . Write number ecu or printscreen wirh kess
FILE SERVICE
