Results 1 to 15 of 20
Thread: pc running slow
    Oct 2008
    Default pc running slow
    can anyone help my pc is so slow when i am typing in the words i sit back and wait for them to appear. I am on windows xp. I have run tune up but did not cure the problem. In task manager-processes I have 46 programs running is this a problem? do they need to be shut down? my cpu varies from 2% to 24% rising to 55% when i open a program
    thanks for any help
    rockinbob
    Is it a new Keyboard you are using ? Try altering settings in CONTROL PANEL/ KEYBOARD.
    V.I.P. Member dctyper's Avatar
    Jun 2008
    46 programs or proccesses?
    Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
    previous life dm800hd and 500c on cable screw you nag3
    Whats your processor and memory size as it seems to me your resources are running low.
    DK Veteran mickyboy's Avatar
    Nov 2008
    paisley
    46 ~~~~in programs where the ~~~~ you wired up to the pentagon m8 ?? try system tools defrag/disk clean up the basics see what you got
    Oct 2008
    Quote Originally Posted by nevovx View Post
    my processor is pentium 4 2.8 my memory is 512
    Senior Member oldeno's Avatar
    Addition :
    Run Antivirus, antimalware, antispyware, etc.
    Run registers cleaner and clean all useless files.
    If it does not work,the machine needs to be formatted
    and setup new Windows (last thing you should do)
    Good luck.
    try to repair the windows sometimes it works as well
    Download Ccleaner. Use the disk clean up on it and also the registry tweak and then defrag the system. Download for Ccleaner here >>> Download CCleaner 2.24.1010 - Download - FileHippo.com
    Oct 2008
    Quote Originally Posted by vtorres View Post
    thank you for your reply will do as you have said
    alotmentman
    Guest
    hi mate sorry to jump in on you /im running a pc windows xp proffesional amd althron 64 prosser 3000+958mb nivida g force 6100 wen down loading etc its running slow i can up grade to 4gb in memory would that resolve the speed problem thanks any info to help me much appreiceted
    Mar 2011
    Rockin bob i would suggest getting some more ram
    check ur motherboard manual to see how much it can take
    i would say it could take upto 4gb
    and all the other things like defrag and disk cleanup
    also type in ur search bar MSCONFIG click the startup tab and turn off anything u dont want to start up DO NOT TURN OFF ANY RUNDLL32 OR ANYTHING POINTING TO C:\WINDOWS FOLDER
    hope this helps
  13. #13
    Junior Member Tamarc's Avatar
    North Lanarkshire
    i would deffo look at how much ram you have 512 is not very much these days,at least another 512 but another gig of ram would be better,maybe its time you looked at doing a reinstall ? esp if no better result after doing defrag,ccleaner etc
  14. #14
    _-__
    Red face Alternative to ccleaner
    you can try
    Malwarebytes' Anti-Malware
    worked for me
  15. #15
    V.I.P. Member lagerland's Avatar
    Sep 2010
    Right ere Right now.......
    stick another gig of ram in mate should help or wipe it and reinstall the operating system make sure you have all drivers first could be a nightmare otherwise.......
