Results 1 to 8 of 8
    Default Ok am I missing something? Re: Openmedia / Dm500c
    Ok I feel I am missing something.
    My current status is that, I have purchased a OM 500cs. I have updated to the DKv1.1 Image via Dreamup. Then I have updated the roms to "new_roms" (that were linked in one of the posts) via ftp along with the keys into /var.
    Now, when I go to do an automatic scan it finds a transponder with lock blinking on and off. Then once a transponder scan is done, it gets about 10 mins in and freezes up.
    Not sure if its down to the incorrect key file or something. But I am guessing they are only needed to decode the channels.
    I am in Glasgow and am getting a perfect cable line into my conventional box. So I was wondering if am doing something out of the ordinary, or I just have a crappy box?
    Cheers for the help in advance.
    V.I.P. Member dctyper's Avatar
    Jun 2008
    500cs? make sure your using the cable bit and not sat
    Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
    previous life dm800hd and 500c on cable screw you nag3
    Quote Originally Posted by dctyper View Post
    Yep, its definitely switched to "Cab" even when flashing.
    Ok, I have updated the roms and keys to 755. I think thats maybe where the freeze issue came from. However, I am still not getting any channels using Bruteforce.
    Anyone have any Ideas ?
    V.I.P. Member Curious123's Avatar
    Apr 2008
    Have you set the cam to Evocam 2.13?
    Ok, I have disconnected the splitter and I seem to be able to find channels(not all of them). However when going in to download evocam 2.1.3, It sometimes shows the Kaos extra settings, then freezes.
    At reboot, it also show "This directory doens't contain anything playable!", not sure what that is. I have tried to download evocam 2.1.3 but it says installing, and then reboots?
    I realise that this thread is pretty much me posting, but does anyone have any ideas.
    Apr 2008
    Turn to S*y Sp1 and try restartin your evocamd until it clears.
    I can't see to access the cams in the slot manager. Not sure what is going on. The file is in the var/bin directory, but the manager doesn't seem to see it.
